RB26 6 boost manifold T4 not split pulse $650
MrTurbo t79 $650
N1 water pump $100
RB26 12mm ARP head studs $150
RB26 complete intake manifold with TB's $350
RB26 coil packs and loom $150
Located on the sunshine coast QLD
Intake manifold will be sold complete. Send me some Offers, do want this stuff sold.
Don't ask me what's the lowest I'd sell this for.....
  • 4 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
