1999 Nissan Stagea RS4 WGNC34 RB25DET Neo - 148,000 kms
4 speed tiptronic auto - a/c - p/s - twin sunroof - roadworthy certificate - 10 months rego
2nd Australian owner - purchased completely stock in 2010 with 85,000 kms - first compliance Dec 2009
full service history - fastidiously maintained - no expense spared - 15k in receipts!
only ever run on BP Ultimate 98 - recently made 134 rwkw at 11psi on RacePace dyno
very practical with good fuel economy (500 kms to 60L)
pleasure to drive in all road conditions: quiet, comfortable and very compliant
regretful sale however just purchased new car - inspection will not disappoint
factory series 2 features:
ATTESA E-TS 4wd system - diff/transfer case lock (for snow/ice) - ABS brakes
driver & passenger SRS airbag - electric windows - electric fold in mirrors - central locking - keyless entry
climate control - adjustable steering column - privacy glass (rear) - floor mats (5) - cup holders (front & rear)
adjustable xenon HID headlights - fog lamps - Dayz side skirts - auto trans cooler - roof rails - auto tailgate
modifications / accessories:
aftermarket dump & front pipes - high flow cat - standard exhaust cat back
Bilstein height adjustable shock absorbers - Whiteline springs
Whiteline 24mm stabilizer bars (adjustable front - fixed rear)
Whiteline adjustable camber kits (1x front - 2x rear) - Whiteline adjustable castor kit (front)
310 mm r34 GTT 4-pot front brake upgrade - QFM HPX pads & new shims - Penrite RBF600 brake fluid
17" forged BBS Autech 260RS wheels - Yokohama AR01 225/45/17 tyres (new) - rear guards rolled
Alpine CDA-9887 head-unit - Hertz HSK 165XL 6.5" front splits - Focal 165CVX rear speakers
Kicker ZX-350.4 amp - Audison RCA leads - Alpine iPod control cable - Dynamat in all 4 doors
centre console lid re-trimmed in black leather - Tint-A-Car darkest legal tint (front)
lots of brand new genuine parts fitted:
head gasket - timing belt - front crank & cam seals - rocker cover gaskets - rear moon seals
intake & exhaust manifold gaskets - dump pipe / front pipe / catalytic converter gaskets
coil packs - coil pack loom - oxygen sensor - radiator - heater core
auto trans fluid & filter - sump gasket - shift solenoids
weather shields - wiper blades - washer jets
new O'Brien's windscreen - heavy duty 600CCA battery - a/c system serviced regularly
rebuilt front driveshaft's - front & rear diff oils replaced
PRICE: $12,500
contact Chris on 0439-172-522 - I am located in Pakenham VIC
Edited by krzysztof
  • 4 weeks later...
  • 1 month later...
  • 5 weeks later...
  • 1 month later...
  • 1 month later...
  • 5 months later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
