I have my Supra up for sale i have owned this car for 6yrs now and well the distance travelled in that time would be under 1000km it was bought for 33k off a really good friend of mine she had the engine just rebuilt as i bought it. and spend another 10k on it. my loss is your gain. Only the best has been used on and in this car. currently tuned to 15psi and cams still set at zero makes 475hp through the big wheels on its run in/ me get used to going from a n/a supra to this. HUGE potential i just havent had the time to enjoy this car..
Car is driven daily in and out of the workshop and the fluids changed every 3-6mths
no test drives will be done but happy to have it put on a dyno in front of serious buyer
$22k ono
0420 444 221 - leave a message if unavalible
may swap for 33gtr,32gtr or an fd rx7...
video of supra idling
Toyota Supra RZ
1993 Model
xxx km’s
0 Months Registration
Engine
2JZ-GTE
JE Pistons (87mm)
Eagle Con Rods
ARP Head Studs
ARP Main Studs
HKS Head Gasket
HKS Timing Belt
HKS Cam Gears
HKS 272 stage 3 cams
ATI Harmonic Balancer
Turbonetics T72 Turbo
Tial 45mm External Wastegate
880cc Injectors with Custom Fuel Rail
SX Fuel Regulator
80mm Billet Throttle Body
Custom Made Stainless Steel Exhaust Manifold
FMIC with custom piping
3.5” Exhaust System, with Custom Dump Pipe
Bosch Individual Coil Packs
Microtech LTX12S ECU
2 x Bosch 044 Fuel Pumps
2L Surge Tank
Custom Radiator Overflow Tank (Polished Stainless Steel, Braided Lines & Speedflow Fittings)
Custom Oil Catch Can (Polished Stainless Steel, Braided Lines & Speedflow Fittings)
Polished Stainless Steel Radiator Pipe
Reconditioned Head
Gearbox
Rebuilt Auto Gearbox (Manual valve body)
Transmission Oil Cooler
3200 stall converter
Exterior
Alpine Silver
Super Low King Springs
20” BMS Rims with 275’s Rear (Sp Maxx $800ea)new 235’s Front (near new)
Clear side indicators
Tinted Windows
Electric Antenna
Remote central locking/keyless entry
Interior
FACTORY INTERIOR SWAP
optional Recaro sr3
Pioneer CD/MD Player
Front and Rear Speakers
Sony Explode Amp
Turbo Timer
Electronic Boost Controller
Autometer Boost Gauge
Autometer Oil Pressure Gauge
Electric Windows/Mirrors
Electric Drivers Seat
Air Con/Heater
Possibly open to swaps .......
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
