Has anyone else had an issue with the fan eating away at their shroud when using a Koyo radiator with stock shroud?
Mine seems to do it at high speed when the air pushes on the radiator just enough so that the shroud connects with the fan.
Never used to do it until I installed N1 engine mounts and happens only above 200km/hr. I thought I had fixed the issue by cable ties on the top uprights of the radiator to the rad support which worked fine which seemed to work ok but it began munching the shroud again at Racewars at speeds above 250km/hr
Pic below of the damage, it's not bad just don't want it to happen with my new shroud/fan
If you watch some old BMI videos you see the Japs carefully cut out the the flat area of the shroud to prevent the fan from making contact...
Let me find a still/photo and show you what I mean.
** edit can't find on google images, and going cross eyed looking lol
I'm trying to get away with no cutting the fan or shroud on the new one
don't cut the fan at all, a little bit of unbalance on the fan and you pput heaps of pressure on ur water pump as its connected to the fan. my fan had the edges cut and broke my water pump into 9458-239840-3492 pieces at like 7000 rpm
  • 1 year later...
Update on this, I tried several things including solid mounting the top radiator mounts, getting a new fan, getting a new shroud... All to no effective result and it kept just eating away at the shroud.
Seems to be an issue when you have a Koyo radiator with a stock fan/shroud and Nismo engine mounts.
I've ended up buying a Gktech fan (plus adaptor) and another new shroud and it doesn't hit at all, actually has a reasonable amount of clearance. The Gktech fan doesn't work as well as the OEM Nissan one but still is able to keep my temps in the low 80's in traffic. No issues while on track at all as the airflow is more than effective.
Thought I would post because I'm sure others will have the same issue in the future!
  • Like 4
thanks for the update. I have the koyo, but it is not installed as of yet. I will likely fiberglass a part in at the shroud and trim it out where yours touched.
Keep an eye on the GKtech fan; I ran one for a while and found that whilst it could control temps ok for a short while, temp would slowly rise in traffic until reached a point where it could no longer control, and temp would spike from high 80 to over 100 degrees in a very short time. This was whilst using a 3 core 50mm rad, and a brand new OEM fan clutch.
Back to an OEM fan, with nothing else changed and the car would never go over 86 degrees in any scenario
I know Mat Wooten (GeeTeeTee) had a very similar experience to mine with the GKtech fan.
It also sounded like a low flying aircraft all the time which drove me mad.
I had good success with a heat gun and a wooden roller on the shroud to push back the offending area that was fouling the fan under deceleration (engine mounts on the VQ are quite soft).
Just keep a wet rag handy to cool the area your working on as the shroud can sag or go brittle if you overheat it.
I have done 3 sprint events and 2 track days with no issues. It's not a "traffic" driven car but I have been keeping a close eye on the temps. While the OEM fan kept the temp at thermostat temp at all times in traffic the GKtech rises to the point where the clutch fan kicks in and then stays steady there.
Even when idling in pits after belting the shit out of it on track I have not seen it go above 90deg
  • Like 1
That's a win then!
I like their products, but the fan does seem a little hit & miss on anything other than SR's.
If it works in your application; you can't argue, and the price is right too.
I had the same problem with a Ron Davis radiator, my fan caught the shroud and jammed while I was on track, at the time I only had my factory dash in there instead of my Racepak IQ3 so I didn't have any warning lights for temps, I didn't realise there was an issue until the Link G4+ put the car into limp mode when the water and oil temps went through the roof.
I've now gone to twin electric fans
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
