SAU NSW runs our events under AASA insurance so AASA or CAMS licenses are accepted.
If it is a CAMS sanctioned event they may not accept AASA.
CAMS requires you to be a paying member of a CAMS car club (SAU NSW is a CAMS club).
AASA does not require you to be a member of any club. Just download the form from their website and fill it in.
Hope that clears things up.
Perfect! One question, however: At the end of the AASA form, there is a "competency declaration by club/organisation/person" - is this a requirement, or optional only for reference?
Thanks!
AASA Licence = sent off via snail mail
SAU NSW = Shell PMd
Next, to claim a spot for Texi - do I have to go through both eventbright AND the email?
"The only way to secure a spot is through sending in an entry form/email and payment through eventbrite"
Thanks for the help guys
If you could email the following details through to us, it would be appreciated as it allow us to keep track of entries easier.
Electronic entry details sent to skylinesausnsw@gmail.com
Please include:
Full Legal Name (as entered on bank deposit or Eventbrite):
Forum Alias:
Car Make:
Car Model:
and payment can be made either through Eventbrite or Bank Transfer.
Please include:
Forum Alias:
Car Make:
Car Model:
Done! See you there, guys!
Hey mods, is there an age restriction for passengers?
With my Meniere's, osteoporosis, vertigo, gastric reflux & Tourette's - Yes!
Srsly we've had kids before so long as the seatbelts cover body mass. Hope this helps.
  • Like 1
Yeah we've had kids before but I didn't know if there was any legal requirement, thanks Tez!
I would be checking with the insurer about age limit cause I'm fairly sure cams is 16years old ( but could be wrong ) and while you can psychically do the courses with with someone younger if something happens " I thought " isn't going to help you, this really is one of those things you really need to know for sure for insurance and liability reasons
Wow. ok! I'm not sure on whose head it would be, but I have a mate whose kid would like to jump in my car and I want to be above-board. I'd like to be able to tell him yes or no soon so he can come dressed appropriately and with a helmet. Indemnity is fine, my mate will sign off... as long as you guys are cool, we're cool. =-]
IN REGARDS TO PASSENGER AGE:
Passengers must not be under the age of 15 years. All under 18 year old passengers must sign a passenger indemnity on the day and must have approval from their parent or guardian. If the parent or guardian is not present at the event, a letter giving permission to participate must be received
I would go 1 further then that and make ALL passengers sign the indemnity form and for 15-18 year olds have the parent or guardian sign the indemnity form as well, maybe post a PDF with the form to fill out and sign before hand if the parent/guardian can't make it on the day, it is just not worth the trouble should ( heaven forbid ) something goes a miss
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
