SAU NSW runs our events under AASA insurance so AASA or CAMS licenses are accepted.
If it is a CAMS sanctioned event they may not accept AASA.
CAMS requires you to be a paying member of a CAMS car club (SAU NSW is a CAMS club).
AASA does not require you to be a member of any club. Just download the form from their website and fill it in.
Hope that clears things up.
Perfect! One question, however: At the end of the AASA form, there is a "competency declaration by club/organisation/person" - is this a requirement, or optional only for reference?
Thanks!
AASA Licence = sent off via snail mail
SAU NSW = Shell PMd
Next, to claim a spot for Texi - do I have to go through both eventbright AND the email?
"The only way to secure a spot is through sending in an entry form/email and payment through eventbrite"
Thanks for the help guys
If you could email the following details through to us, it would be appreciated as it allow us to keep track of entries easier.
Electronic entry details sent to [email protected]
Please include:
Full Legal Name (as entered on bank deposit or Eventbrite):
Forum Alias:
Car Make:
Car Model:
and payment can be made either through Eventbrite or Bank Transfer.
Please include:
Forum Alias:
Car Make:
Car Model:
Done! See you there, guys!
Hey mods, is there an age restriction for passengers?
With my Meniere's, osteoporosis, vertigo, gastric reflux & Tourette's - Yes!
Srsly we've had kids before so long as the seatbelts cover body mass. Hope this helps.
  • Like 1
Yeah we've had kids before but I didn't know if there was any legal requirement, thanks Tez!
I would be checking with the insurer about age limit cause I'm fairly sure cams is 16years old ( but could be wrong ) and while you can psychically do the courses with with someone younger if something happens " I thought " isn't going to help you, this really is one of those things you really need to know for sure for insurance and liability reasons
Wow. ok! I'm not sure on whose head it would be, but I have a mate whose kid would like to jump in my car and I want to be above-board. I'd like to be able to tell him yes or no soon so he can come dressed appropriately and with a helmet. Indemnity is fine, my mate will sign off... as long as you guys are cool, we're cool. =-]
IN REGARDS TO PASSENGER AGE:
Passengers must not be under the age of 15 years. All under 18 year old passengers must sign a passenger indemnity on the day and must have approval from their parent or guardian. If the parent or guardian is not present at the event, a letter giving permission to participate must be received
I would go 1 further then that and make ALL passengers sign the indemnity form and for 15-18 year olds have the parent or guardian sign the indemnity form as well, maybe post a PDF with the form to fill out and sign before hand if the parent/guardian can't make it on the day, it is just not worth the trouble should ( heaven forbid ) something goes a miss
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
