Hey guys, I've done a fair bit of research but found nothing on comparing the two, Greddy/Trust vs Precision.
So i have a built rb25 with pom cams and my current setup puts out 320rwkw @ 18psi on bp98 fuel with Genuine Greddy td06sh 25g. I get full boost roughly around 4-4.2k revs and hits hard from then. For me thats a bit laggy for street use. I want similar power with much better low to mid range and more linear rather than on/off power.
I was looking into precision turbos as my bro has one on his xr6t and gets full boost from 2.8-3k and freaking 412rwkw on 18psi. PT6766… blooddy 4L fords are crazyy
Now i was looking at Precision 5858 or 5830 or even the 5557. All the billet twin ball bearing with anti surge housing. Will be low mounted with his cast manifold.
So do you guys think i will get a worthwhile improvement with any of the precision turbos over the greddy td06?? power wise and response
cheeeeeerssssss
https://www.sau.com.au/forums/topic/442895-rb25-turbos-greddy-vs-precision/
you have to take it off the manifold if its highmount its really not that hard way easier than spending cash on a new turbo you don't have to
the rear housing will have a 8 or a 10 on the casting were the exhaust gas enters the turbo (for lack of a better explanation)
I may even have a buyer for the 10cm rear housing for you :)
tutumiwo-img600x491-1298788614r9wz2u1802
Edited by 1400r
With that sort of response on an RB25 you are running a 10cm housing. Going from a 10cm to an 8cm housing on that sized turbo will really liven it up in the mid-late 3,000rpm brand but say goodbye to having any pull over 6,250rpm.
I went from an 8cm and tried a 12cm because I couldnt get a 10cm housing and the 8cm was wild. 300rwkws and the think just blazed tyres with so much extra torque down low. Would suggest the 8cm will run better on E85 as it is too small IMO for a 2.5L engine and E85 masks such mismatches.
I ove my Trust turbos but if you want more response then time to change turbo...not pay $400 for a different turbine housing and have a compromised result
E85 won't give you better response; as in, it won't affect the turbo lag. You can tune to have it feel more 'gutsy' off boost if you like, just ask the tuner. Your fuel consumption will suffer though.
If you want the same top end power and better response you can use a smaller turbo increase boost. 18psi is pretty low for a built motor
OR you could go for a smaller turbo, more boost + E85 for even better response and top end.
Whatever I guess it comes down to how much time and money you want to put into it
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
