Hey guys, not sure if this is the right place for this as I'm a new member, But I haven't been able to find out anything about Rb20DE afms, only RB20DET stuff is coming up.
So basically, I just engine swapped my 1989 HCR-32 Rb20det to a Rb20DE because I get my Ps in a month.
Everythings done, but I'm having trouble figuring out what Afm I can run? The DET afm I have does nothing with the Rb20de GTS ecu.
its a standard rb20det 80mm Green label afm.
I can run the car with the DET afm and it does its usual thing like any other car would with no afm, so I un plug the afm and there's no differnce at all.
I have found a Rb20 purple label afm from a Cefiro but I have no idea if that will work.
If someone can link me to what afm will work on a NA rb20de or tell me what will work that would be great!
Thanks in advance
  • 3 weeks later...
Afaik the det afm should still work fine, but the pinout at the plug may be different, hence why its going into safe mode. Maybe worth googling the pinouts and checking.
Also, converting a turbo car to a non turbo car doesnt mean you can drive it on your p's.
Regardless of the engine, when the run the plates and see it was/is a turbo car. Theyll have a chat to you.
Unless. you have it engineered/complied/etc retitling it as a non turbo.
Would have been no different then just pulling the turbo gear off the turbo engine and running the engine as a decomp na. still a turbo.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
