Buying A Fresh Import Car
hey guys, so im planning to buy a fresh import car.which is currently in vic im in sa. the car hasnt been registered yet so what i was planning to do is to fly down and get a permit from vicroads to drive it back to sa and get it registered here. my question is what do i need to have to get a permit from vicroads to drive it back? and when in adelaide, do i just go in for an inspection in regency? also do i need to get brand new tyres before i bring it to regency?
Edited by greychocobo
Normally going over the pits and getting registered is part of the compliance process - so the first question is has it been complied? If not don't go near it. I would be VERY wary fullstop of buying an unregistered fresh import, as if you take it regency they will absolutely tear you a new one on every aspect of the car.
If it is freshly complied, then by law it needs to have had brand new tyres fitted.
I wouldn't be touching the car with a 20 foot pole until/unless it is complied/registered prior to purchase. There must be a reason it has not been, and all the reasons are bad.
I assume that this would be the same as my M35.
I bought it from NSW unregistered, so no number plates, but with a NSW unregistered vehicle permit, which gave me 3 days to get to Vic, and insurance based on the AUS vin. Dealer had to get a roadworthy and a 5 day CTP cover slip instead of NSW Rego.
Drove to Vic and Vic roads treated it as a normal unregistered vehicle.
Had to get Vic roadworthy, vin stamped into the car and car sighted by Vic roads. Payed stamp duty and rego, then got plates and drove home.
Just make sure all the paperwork is correct, such as engine and vin numbers having all the correct numbers on paperwork, and make sure that tyres have been changed and match the size on the compliance placard... The old Japanese one is now invalid .
For sa rego it will need an id check at regency.
They will spot any problem and can issue a defect and won't let you through until it is fixed.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
