So this morning I went to drive and when I turned on my car the tachometer would not work, and the ABS and TCS light stayed on. Turned off, waited 30 seconds, and tried again with same result. Obviously there was an issue, so I shut her off and drove my daily, as I was already late I couldn't afford to sit there and diagnose it.
I came home in the afternoon and decided to check it out. Only, it is now working fine. YAY FOR INTERMITTENT!
So a few things:
- I drove it to work on Monday with no issues, been sitting since then. Never happened before.
- It was raining this morning, and it was early when I started it (morning dew early). It has never been an issue before, but obviously in the afternoon, all the wetness and moisture has disappeared.
- ABS and TCS rely on wheel speed sensors, that is what connects them, but the not sure how the tacho receives it's signal.
- Every other gauge including triple gauges worked, and back lights worked.
Feel free to ask me any questions. The only place I would start looking would be behind the dash, but honestly I have no idea.
I will try and start it tomorrow morning early and hopefully nothing is wrong and it was just an omen to not drive my car for some reason today.
Cheers.
https://www.sau.com.au/forums/topic/442942-dash-cluster-intermittent-issue-r34/
The tacho receives it's signal from the ecu, which receives it's signal from the cas. Your problem is with the ecu to tacho signal, or the tacho itself, because if it was the signal between the cas and ecu the car wouldn't run.
I have had a few R33 tachos play up over the years. It would appear that they suffer from the cracked solder joint issue that causes the tacho to either simply stop working or work intermittently and provide weird readings.
The last one I had it was a simple task to just remove the cluster from the car and swap the tacho with one that I knew worked from another cluster.
Yeah for sure. Cheers for the info! Wasn't sure where that feed came from..
Yeah I may just take the cluster out and re-solder all the pins on the connectors, and I will look for dry joins.
Still, the ABS and TCS light is a mystery though.
  • 5 weeks later...
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
