Hey Guys,
Recently I started having an issue with my HICAS, every couple of minutes the light would come on the dash(even when stationary) which would be followed by a fluctuation in revs and slight noise from the rear end. Now it has gotten a lot worse, when the HICAS light comes on now its very erratic, stiffens up my steering wheel and slightly jerking it and every now and then shuts down my stereo while the light is on the dash. Last night even switching my headlights on seemed to get a rise out of it. Could this be from a bad earth somewhere that is effecting these systems?
It has an aftermarket stereo and turbo timer fitted but they have been in for over a year now and problem is only around a month old.
I still have standard steering wheel and last mod was long before the issue started.
https://www.sau.com.au/forums/topic/442956-hicas-creating-havok/
Certainly sounds like a wiring issue. Being that HICAS components exist at the front and rear of the car, its going to be a bit of a pain to diagnose which part is causing it. Seen as its messing with your stereo and headlights I'd start inside the car, may have to pull the dash out and just have a look at all the wiring. Not very helpful but its a bit of a hard one to diagnose without being there
The #1 concern with these old HICAS computers these days will have to be whether the electrolytic capacitors inside them are still OK, or if they are dying and causing all sorts of other shit to fry in there. I'd be having my HICAS controller apart on the bench in seconds if mine started doing this.
How old is the battery?
Haver you checked the tension on the alternator belt? (R32 is notorious for not liking bad voltages).
Battery is only 1 year old still has good charge. I'll check the belt tension out
I have had the controller open and everything looked sweet, didnt test the capacitors though.
I plan on getting a lockout kit in a couple of months but if theres an electrical issue somewhere I want to sort that otherwise I'll still be having issues elsewhere. Going to try and clean up current earth's and add another and checkover as much wiring as possible to see if I can find any damage
Edited by Spartan-117
Update,
on the way to auto electrician it died in the arse. 1km away SOB. Melted the fusible link off positive terminal. Definitely something not happy somewhere in the car.
I'll update with an outcome from sparky
The standard connections for the fusible links were the problem all along, seen bottom left in picture. Removed the standard connection and just put ring ends on wires and connected directly to battery.
They werent getting enough power from the standard aged connections so HICAS was first system to get the shits with it.
13917104415 bcf4ba2dfa B
All good now, no more warning lights no more dramas
Because this
What now? HICAS would be the exact opposite of what you want in a car to make that sort of driving enjoyable. The whole time you are flinging it sideways the bloody HICAS would be fighting you for control of the rear end because it has no idea what the hell you're doing.
HICAS is a miserable attempt to make a front heavy RWD chassis feel like it has faster turn in than it natively does. Below 7/10 driving its veneer of snappy turn in is acceptable. Above 7/10 it makes the car feel like it's trying to kill you.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
