I don't understand why all the jap car clubs don't unite on a monthly or quarterly basis like melbourne old school are doing and gain members and interest in club exclusive events? The problem is there are too many idiots who drive these things as to why the police target them. If you guys could organize an event that involves the police in some way via donation etc at the right location it might just work...
Mosc is kicking goals right now with their turn outs and keeping the fools away.
How precise do you need to be, I noticed on the facebook page there are pictures of Skyline GTRs in addition to a GTR.
There is no precision. It is a GTR club hence any generation of Nissan-branded GTR is welcome. This means KPGC10 (not that there are any members who own one) to the current CBAR35. In fact, there are more R35 GTRs in the club than R33 GTRs. The R33s are becoming quite rare as they are not as popular. The R32s are by far the most popular and significantly cheaper than R34s, though R34 GTRs are still plentiful within the club.
I'd join the club, but there's no track day / motorsports presence, if you guys set up a track day I'd come along for sure.
There are a few very good mockups getting about, but I guess they are not invited. Will you be checking everyone's Vin in Fast?
  • Like 2
Nah, I don't want to join that club.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
