Not true, there are Holsets which perform very well on performance petrol motors- you have to get the right combos but there are varieties of HX35 which have been used very successfully on RB25s- I very nearly bought one instead of the GT3076R, only reason I didn't was I at the time figured I didn't want an external wastegate/aftermarket manifold setup.
I got HX35 laying around for preferably some one had a 3076 or similar to try it. It was a repair job for a school bus and the customer didn't came back.
They can make the power, how ever there are many options out today which are capable of the same amount of HP with better response and drive ability.
The same can be said for a LOT of popular turbos - everything can't be the best, so everything else has something better than it. The Holsets aren't the best out there, but they are far from the worst, and pretty far up there in terms of value for money.... the trick is just doing the research and identifying which ones are the ones which would work for you.
any opinions on master power turbos?
They seem solid and reliable, I am still waiting for more real world feedback on them before I form an opinion on their power versus response but one of my mates just got his R33 GTS25t tuned with a billet MP595 and made 330kw @ hubs on 19psi with a respectable power delivery, from what he's said.... will have to try and find out more about how it drives etc. It sounds awesome! :D
  • Like 1
i was but i still have the problem of my stock dump...after talking to a few people and umming and aahhhing a lot...i want to use a much easier dump configuration with vband's used for the wastegate..this will allow me to re-make the front pipe and dump to accomodate a couple of things that i also want namely a 3" flexi and a wideband bung....also make it easier to take apart in the future when i 30det it.
I had a hx 35 with internal gate and all it did was over boost. After I changed actuators like 3 times and all different types. I gave e up. I then just tied the gate open and still I was over boosting to about 25 psi. A matter of fact I new from experience I was maxing out the ecu on my rb20det. So i spent 800 dollars on a ROM tune ecu injectors and Z32 AFM. It started to eat the boost up. But after a while I was wondering why it's over boosting even with the gate open and tied open. So off came the turbo. I new it wasn't boost controller or waste gate.
I noticed that the gate flap wasn't opening all the way. I then found online that people were have the same issue. (Internal gate here) it was limited by the cover 5 bolts cover or somthing like that. The flap couldn't open all the way. Next at closer inspection I noticed that it was a internal waste gate but twin scroll t3 turbo. So in short only one scroll would vent and the other would keep on boosting. This has nothing do with it being good or not. But it bugged me for so long that I spent 800 dollars on ecu and injectors along with AFM. Plus down time waiting. I had better results with cheap ass ebay turbos. I just should have done that and change to external waist gate. Besides all the the turbo hit hard when it came in but was way to laggy for me.
Wasn't really blaming the turbo here. Other than the lag it has on a rb25. Keeping in mind that the flap still didn't control boost well. I do believe it came from a diesel truck that only boost form 22/30 psi. Hence it venting from one scroll. I got it free and wasn't complaining.
I know what you mean mate. I just was list my experience with it. But it was free. Totally. Just was a interesting boost issue I had. I personally don't like them. For the money I would pay for one I can get other turbos that just boost faster with less lag. That's me and I do understand that not all people are the same. It would be a boring world if it was like that.
I have been through my share of turbos and aftermarket parts on both cars. So I am hardly having a go at anyone for doing the same as I have done.
Usually the best results came from carefully thinking out what I wanted and paying the right price for the item. Nearly every shortcut I took ended up taking longer to sort out the issues created.
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
