Not true, there are Holsets which perform very well on performance petrol motors- you have to get the right combos but there are varieties of HX35 which have been used very successfully on RB25s- I very nearly bought one instead of the GT3076R, only reason I didn't was I at the time figured I didn't want an external wastegate/aftermarket manifold setup.
I got HX35 laying around for preferably some one had a 3076 or similar to try it. It was a repair job for a school bus and the customer didn't came back.
They can make the power, how ever there are many options out today which are capable of the same amount of HP with better response and drive ability.
The same can be said for a LOT of popular turbos - everything can't be the best, so everything else has something better than it. The Holsets aren't the best out there, but they are far from the worst, and pretty far up there in terms of value for money.... the trick is just doing the research and identifying which ones are the ones which would work for you.
any opinions on master power turbos?
They seem solid and reliable, I am still waiting for more real world feedback on them before I form an opinion on their power versus response but one of my mates just got his R33 GTS25t tuned with a billet MP595 and made 330kw @ hubs on 19psi with a respectable power delivery, from what he's said.... will have to try and find out more about how it drives etc. It sounds awesome! :D
  • Like 1
i was but i still have the problem of my stock dump...after talking to a few people and umming and aahhhing a lot...i want to use a much easier dump configuration with vband's used for the wastegate..this will allow me to re-make the front pipe and dump to accomodate a couple of things that i also want namely a 3" flexi and a wideband bung....also make it easier to take apart in the future when i 30det it.
I had a hx 35 with internal gate and all it did was over boost. After I changed actuators like 3 times and all different types. I gave e up. I then just tied the gate open and still I was over boosting to about 25 psi. A matter of fact I new from experience I was maxing out the ecu on my rb20det. So i spent 800 dollars on a ROM tune ecu injectors and Z32 AFM. It started to eat the boost up. But after a while I was wondering why it's over boosting even with the gate open and tied open. So off came the turbo. I new it wasn't boost controller or waste gate.
I noticed that the gate flap wasn't opening all the way. I then found online that people were have the same issue. (Internal gate here) it was limited by the cover 5 bolts cover or somthing like that. The flap couldn't open all the way. Next at closer inspection I noticed that it was a internal waste gate but twin scroll t3 turbo. So in short only one scroll would vent and the other would keep on boosting. This has nothing do with it being good or not. But it bugged me for so long that I spent 800 dollars on ecu and injectors along with AFM. Plus down time waiting. I had better results with cheap ass ebay turbos. I just should have done that and change to external waist gate. Besides all the the turbo hit hard when it came in but was way to laggy for me.
Wasn't really blaming the turbo here. Other than the lag it has on a rb25. Keeping in mind that the flap still didn't control boost well. I do believe it came from a diesel truck that only boost form 22/30 psi. Hence it venting from one scroll. I got it free and wasn't complaining.
I know what you mean mate. I just was list my experience with it. But it was free. Totally. Just was a interesting boost issue I had. I personally don't like them. For the money I would pay for one I can get other turbos that just boost faster with less lag. That's me and I do understand that not all people are the same. It would be a boring world if it was like that.
I have been through my share of turbos and aftermarket parts on both cars. So I am hardly having a go at anyone for doing the same as I have done.
Usually the best results came from carefully thinking out what I wanted and paying the right price for the item. Nearly every shortcut I took ended up taking longer to sort out the issues created.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
