just got given some info from the gold coast bulletin about the future of the V8s' at indy..
they need to upgrade the pit area to allow enough room for the number of cars in the championship now! if this upgrade is not done then the V8s will have to be removed from the bill...
they are asking poeple to answer this question:
"Do you support a new pit area on Macintosh island to keep the V8 Supercars at indy?"
All you have to do is SMS yes or no, or provide a comment under 25 words,and SMS it to: 0416905147
you can email your opinion to veiwpoint@gcb.newsltd.com.au
the problem they are facing is its a park and they need to remove trees (2%) 30 trees in total, it will mean more parking for the area and the V8s' will run at indy in the future.
if you like to go to indy and see the V8s' then let them know!!
Thanks, Matt....
https://www.sau.com.au/forums/topic/44303-v8s-at-indy-300/
i think they should scrap the V8's and get the amature race/cruise community of the gold coast to replace them..............
the pit stop can be any macca's carpark and bonus points are awarded to neon's and all maner of rice. bonus points for chrome should be awarded on a 'per meter squared' basis. also, however many people you have in your car acts as a points multiplyer. ie, 2 people in the car means 2X points, 4 people means 4X points..............
hell i'll buy a ticket to watch that................at least they'll still drive like nutter in the rain :cheers:
https://www.sau.com.au/forums/topic/44303-v8s-at-indy-300/#findComment-906212
lol you might be onto something there paladin.
But on a serious note there are more then enough hi-powered import/v8/exotics around here to put on a few good races and would compliment the indy cars nicely.
Inexperianced drivers with no race licenses in performance cars racing eachother would make for good spectator/tv viewing but I’m not sure whoever runs the show would like it :cheers:
maybe some time trials?
PS v8's should be there but only if they race after the indycars so they get rained on for a change :ghost:
https://www.sau.com.au/forums/topic/44303-v8s-at-indy-300/#findComment-906461
Well I would have to say I enjoy the V8 supercars more than the Indys... Having been to both Indy and Bathurst numerous times, I can say the V8's provide a much more physical and interesting race... They are nowhere near as fast as the Indy's but definately more involving...
IMO
https://www.sau.com.au/forums/topic/44303-v8s-at-indy-300/#findComment-907418
I'm with strutto, i'm a dedicated V8 supercar fan and watch every race and always attend the QLD 500 (or 300 now). I go to indy for the V8's, the champ cars are pretty cool but if there was no V8's i wouldn't go.
SMS sent!
https://www.sau.com.au/forums/topic/44303-v8s-at-indy-300/#findComment-908621
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
