Why only change the front diff oil? What about rear and transfer case?
Also, I have wanted that mines exhaust for a long time. How much did it cost? If I remember correctly it's not cheap
Yea we ran out of time. So will get to the rear diff and transfer case oil next time.
  • 4 weeks later...
  • 3 weeks later...
Lol why am I sceptical as to whether that r34 on the first page is the same as the one above?
Also, your claimed g35 picture is of a car in Toronto, Canada
Why should you be skeptical?
Yes, the G35 picture was taken in Toronto, Canada.
  • 3 weeks later...
etang, fellow GTR owner from HK. Congrats on your purchase, I saw the ad on 28car and you got to it before I did! May I ask where are you getting your HKS Fcon tuned in HK? I'm running 2530s and the dyno map looks rather flat in the mid range. Grateful for thoughts from other forum members on whether this is a normal curve for 2530s. Thanks
Edited by mtam22
My HKS F-Con V-Pro was tuned at Jun but I'm going to ditch the HKS and use Haltech.
  • 1 month later...
  • 1 year later...
It has been a while since I have updated this, since the last post I have done the following...
I have successfully converted from HKS F-Con V-Pro to Haltech Platinum PRO Plug-in for my 1999 GTR R34 V Spec. The details can be read here, http://www.sau.com.au/forums/topic/444310-converting-to-haltech-platinum-pro-plug-in/
Then to get ready for tuning I installed ASNU 750cc Injectors, OEM Fuel Rail, OEM Fuel Pressure Regulator, OEM BOV, Fluidampr , Tomei Adjustable Cam Gears , and fixed the leaking waterpump.
And during the downtime I also installed the white sidemarkers and front turn signals, painted the lower bumper to body color, as well as the removed the JUN wings and swapped back for OEM wing stands.
Edited by etang789
  • Like 1
Last week I have finally got to dyno tune my car and the result was pretty good.
It was done on Dynapack Dyno
468whp
414lb-ft
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=4e60b0d8160e580c0bec1830f453193b&app=forums&module=ajax§ion=topics&do=quote&t=443066&p=7679809&md5check=02e41fdaf099180a6bfd36efc11d9187&isRte=1,6YgIICLrb3,true,false,ve8htUpDj-A');</script>r34 2.jpg&&0){for(var>
How is it driving now compared to before the last tune ?
Love the colour and the pics of the car are great :)
The last tune on the HKS F-Con V-Pro was for the stock turbos, and previous owner upgraded to HKS GT-SS right before selling the car to me without tuning the car again.
After switching to Haltech the car is much smoother to drive than the HKS F-Con V-Pro even before proper tuning. After dyno tuning the car is much more solid and the power is wider and stays all the way up to redline.
This is my latest addition over the weekend after the dyno tune was GaugeArt for my Haltech ECU. It was fun the playing with this using R35 themed MFD background. It also makes it much easier to monitor the wideband sensors without addition gauges or laptop. But the problem is you cannot remove or reposition the Haltech Logo, I'm emailing GaugeArt about this already.
Edited by etang789
  • Like 4
More info on that Gauge Art setup?
How does that interface with the R34 MFD?
Can you switch between the Haltech display and the R34 MFD display?
There doesn't appear to be any text on those gauges to say what they are?
The gaugeART is pretty simple it gets data from my Haltech Platinum Pro and output as video. Then I just use the R34 MFD video input to display it, so I can switch between stock R34 MFD screen and gaugeART screen with the TV button on the MFD.
There weren't text on those gauges because I haven't got time to play with the font types. I will need some expert in Photoshops to get everything right.
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
