hey guys was looking at fitting a r33 steering rack into my r32 gtst 4 door. can it be done without removing hicas bull;shit? and what tips and tricks you guys got for me?
also wanting to put r33 or r34 lower control arms in. 1. will the fit and 2. will they make a difference?
thanks John.
https://www.sau.com.au/forums/topic/443080-r32-steering-upgrades-questions/
If you want more steering lock im assuming drift or similar ?? even if not...take the hicas out fullstop
R33 rack will fit yes
If you want the most lock out a std rack for and r32 put a ca18de or even better an s14 steering rack in ... less turns lock to lock and little bit more lock, you'll need to re route lines a little but very easy
R33 , S14 front lower LCA's will both fit and are approx 10mm+ longer
the difference on all that is dependant on what adjustable arms, other suspension, ride height etc you have already
but all things being equal longer from LCA;s will induce more camber and widen current stance
If you are drifting and are looking to get the most out of the R32 steering (without spending ridiculous amounts of money) you will need
> R32 steering rack is fine, but R33/S14 is probably worth it if your current rack is no good.
> Getting your knuckles modified by JDI Fabrication in melbourne
> Longer tie rods (a requirement if you are getting your knuckles modified)
> Standard R32 tie rod ends are fine
> Steering rack spacers
> Modifying X-member to move the steering rack forward
> R33/S14 lower control arms as they are 10mm longer
All of these are about as far as you can take it without getting ridiculous. The longer tie rods you need come from an A33 maxima and have a part number of RE1050, the standard tie rod ends are fine.
I just received my R33 LCA's today and measured them as there was a lot of grey info on the net about them. They are almost exactly 10mm longer and the bump stop is a concave shape as opposed to the R32 item which is straight, effectively allowing more steering angle before it hits bump stops.
And here is the crossmember when it has had the steering rack mount moved forwards 15mm
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
