hey guys was looking at fitting a r33 steering rack into my r32 gtst 4 door. can it be done without removing hicas bull;shit? and what tips and tricks you guys got for me?
also wanting to put r33 or r34 lower control arms in. 1. will the fit and 2. will they make a difference?
thanks John.
https://www.sau.com.au/forums/topic/443080-r32-steering-upgrades-questions/
If you want more steering lock im assuming drift or similar ?? even if not...take the hicas out fullstop
R33 rack will fit yes
If you want the most lock out a std rack for and r32 put a ca18de or even better an s14 steering rack in ... less turns lock to lock and little bit more lock, you'll need to re route lines a little but very easy
R33 , S14 front lower LCA's will both fit and are approx 10mm+ longer
the difference on all that is dependant on what adjustable arms, other suspension, ride height etc you have already
but all things being equal longer from LCA;s will induce more camber and widen current stance
If you are drifting and are looking to get the most out of the R32 steering (without spending ridiculous amounts of money) you will need
> R32 steering rack is fine, but R33/S14 is probably worth it if your current rack is no good.
> Getting your knuckles modified by JDI Fabrication in melbourne
> Longer tie rods (a requirement if you are getting your knuckles modified)
> Standard R32 tie rod ends are fine
> Steering rack spacers
> Modifying X-member to move the steering rack forward
> R33/S14 lower control arms as they are 10mm longer
All of these are about as far as you can take it without getting ridiculous. The longer tie rods you need come from an A33 maxima and have a part number of RE1050, the standard tie rod ends are fine.
I just received my R33 LCA's today and measured them as there was a lot of grey info on the net about them. They are almost exactly 10mm longer and the bump stop is a concave shape as opposed to the R32 item which is straight, effectively allowing more steering angle before it hits bump stops.
And here is the crossmember when it has had the steering rack mount moved forwards 15mm
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
