http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb26dett-skyline/1989-2002-rb26dett
Pick your poison! Direct easy drop ins that idle perfectly and no issues with E85, I would be going the 1200cc as there is no downside apart from the small price increase
Shipping is usually less than a week from the USA
Yeah was going to say, the ones you have now should be fine
Unless its a GTR and you are running twin GT-SS turbos?
But I ran a GT2835 HKS turbo with 555cc injectors, plenty of room left in them
Yes it is a R34 GTR so its twin HKS GT-SS
Here is the details on the build project http://www.skylinesaustralia.com/forums/topic/443066-finally-a-gtr-r34-owner/
On 98RON your current ones will do just fine.
Yes it is 98RON
But now I see the injector cycle on the MFD is at 100% on full boost
Edited by etang789
Works fine, no need for aftermarket. Looks better too
understood.
I was also thinking to switch back to stock fuel rail as well, is the upgraded HKS fuel rail necessary? I have no clue since this is how it is when I bought the car
The injectors you have in the car should be more than enough for the power those turbo's can produce.
I'd say who ever tuned the car has set the injectors to 100% at WOT.
When you have your foot down does a big puff of black smoke come out and it smells fuelly?
Totally agree.
Stock 440cc GTR injectors will do 300rwkw without even a rail pressure increase. If 555cc injectors can't do 340rwkw which is all GT-SSs will make... then there is something wrong.
If you need a bit of headroom, just add an extra 3-4psi to base fuel pressure, that alone will be enough once up on boost to give the fuel supply needed.
Definitely a waste of money changing ANY parts from what is currently fitted - they will do the job.
it smells fuelly for sure and my rear bumper is black, well I dont have a cat thou...
Totally agree.
Thanks for the advice. I guess I will just have it retuned for now... just need someone that is willing to do remote tune for me.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
