http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb26dett-skyline/1989-2002-rb26dett
Pick your poison! Direct easy drop ins that idle perfectly and no issues with E85, I would be going the 1200cc as there is no downside apart from the small price increase
Shipping is usually less than a week from the USA
Yeah was going to say, the ones you have now should be fine
Unless its a GTR and you are running twin GT-SS turbos?
But I ran a GT2835 HKS turbo with 555cc injectors, plenty of room left in them
Yes it is a R34 GTR so its twin HKS GT-SS
Here is the details on the build project http://www.skylinesaustralia.com/forums/topic/443066-finally-a-gtr-r34-owner/
On 98RON your current ones will do just fine.
Yes it is 98RON
But now I see the injector cycle on the MFD is at 100% on full boost
Edited by etang789
Works fine, no need for aftermarket. Looks better too
understood.
I was also thinking to switch back to stock fuel rail as well, is the upgraded HKS fuel rail necessary? I have no clue since this is how it is when I bought the car
The injectors you have in the car should be more than enough for the power those turbo's can produce.
I'd say who ever tuned the car has set the injectors to 100% at WOT.
When you have your foot down does a big puff of black smoke come out and it smells fuelly?
Totally agree.
Stock 440cc GTR injectors will do 300rwkw without even a rail pressure increase. If 555cc injectors can't do 340rwkw which is all GT-SSs will make... then there is something wrong.
If you need a bit of headroom, just add an extra 3-4psi to base fuel pressure, that alone will be enough once up on boost to give the fuel supply needed.
Definitely a waste of money changing ANY parts from what is currently fitted - they will do the job.
it smells fuelly for sure and my rear bumper is black, well I dont have a cat thou...
Totally agree.
Thanks for the advice. I guess I will just have it retuned for now... just need someone that is willing to do remote tune for me.
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
