Some maybe familiar with what a "Fuel Catalyst" is, for those that aren't I have attached a link below or just do a google search....
I guess these are one of those "sceptical/gimmick" products that claims to do a number of things:
The benefits include:-
-Reduced fuel comsuption
-More power
-Reduced exhaust emissions (HC & CO)
-One treatment lasts for 400,000 kms
-Simply fitted and requires no maintenance
-Easier starting and smoother running
-Suitable for use with catalytic converters
-Keep engine oil cleaner
-Eliminates engine 'coking'
-Quickly pays for itself
-Allows the safe use of unleaded petrol in all petrol engines.
Basically there are 2 types;
a) Inline - which is placed along the fuel lines, before or after the fuel filter.
B) Intank - metal balls that sit inside the fuel tank.
The Particular units we'll be testing are the Broquet Intank & Inline units & Algae-X products. AlgaeX is a little different where it uses magnetics, and is more common on Diesel & Marine equipment, it has a similar effect, but is also claimed to "Condition" the fuel system including injectors, tank etc etc. So we asume this will be more a long term rather than immediate effect.
The test is planned for this Saturday, and will be done at ICE Performance on their dyno. I'll keep you'll updated.
https://www.sau.com.au/forums/topic/44309-test-results-fuel-catalyst-products/
You should get a camera crew and sell it to today tonight or something.
At least get the story to pay for itself
Yeh.. good idea!! I doubt it though.
I still got to fork out $$ for the Dyno time. I know these have been covered before on ACA & TT, but nothing like seeing it for yourself.
dont they need to be run in so to speak. Ie at least 500kms before they start to work. So if u do a back to back dyno it will prolly show nothin, even thou they prolly dont work?
Yes & No! Both products have an immediate effect, but the AlgaeX has an additional product a liquid based "Fuel Catalyst" which is added to the tank, this takes around 2-3 fills to see any results.
I'll be interested to hear the results because the marketing & salespeople give me a really bad vibe about these products.
I think you will find that the manufacturers will do their best to distance your tests from their product if the results arn't positive. They will however ignore any inconsistancies in the testing if the results are good.
One manufacturer has a written statement that the type of test you are conducting (ie short term dyno tests) will not produce reliable results.
browny, it's going to hard for "Broquet" at least to distance themselves, as they will be present and participate in the run. The reason we are doing this, is because I was given a smaller unit to try about 3weeks ago, and found it to be slightly positive only by the "hard to prove"seat of your paints feel. It seemed to have reduced knocking which I monitored via the Apexi Power FC Hand Controller, response felt a little better, and ICE had the car on the dyno last week, where they found the AF Ratio's to be richer in the midrange. The problem with the current unit is we think it is restricting fuel flow and looking at the larger units or the intank units.
So far... it seems "OK" the claim of saving fuel???well I still get around 300Km out of a tank, so I can't say it helps with saving fuel. Broquet have been very helpful and stand by their claims on what this product can do. I guess we will see on tomorrow.
Allright... we did a some runs tonight on ICE's dyno. And sure there were a few "ok! maybe alot" of laughs about these "Stealth B52 Uranium Bombers"..and with possibly goods reason. It was best to be sure and dyno the units, than assume the hard to prove "seat of your pants feel"..
We tested all the units within a 2-3hour period tonight, doing around 4-5 runs per test with about 15-25minutes between each procedure, nigel was also wearing his "ear phones" to monitor knocking, and "just in case his girlfriend called to say dinner was ready" :P.
The test we did were:
1) Broquet B40 (retails $500 fitted) Unit connected between the fuel filter & engine to manufacturers specs.
2) Broquet Top Fueller Competition (retails $1200 fitted) Unit connected between the fuel filter & engine to manufacturers specs.
3) Non of the above, back to stock standard fuel line.
A couple of things, we generally spoke about, were maybe these units don't have the same effect on cars pushing higher HP running Premium ULP. In our tests it failed to show any conclusive difference, and we decide to return the car back to normal.
I will upload the graph tomorrow.
I hope you didnt have to pay for these to test them?
thanks for putting up the results.
Edit:
You mention perhaps they weren't meant for big HP cars, but by the sound of the name, and the cost, of the second unit you tried, it wasnt designed for hyundai excels used by old ladies:)
I have attached the dyno sheet.
The 3 test are as follows:
1) fuel check
This test is done without any fuel catalyst, with the cars fuel system returned to stock
2) big red check
Nige decide to call this test Big Red, coz the unit looks like a uranium bomb. This is the apparnent top of the range unit "Top Fueller" retailing for $1200. see pic below. It is supposed to handle upto 1000hp.
3) AFC Tune
This test was done using the B40 unit retailing for $500.
I'm not too technical on the dyno graph reading etc etc, but on the advice of the boys, we concluded the unit had no real effect as claimed by the manufacturer.
I fairness to the monufacturer, they did say give the car around 3-5000Km and see if there is any difference without the unit...
Those AFRs are quite different between each run though..
Any reason for that?
If the computer was returned to suit the different conditions it might change the results somewhat?
Looks to be about 0.7 difference in the AFRs.
Would there be much difference in tuning it to this?
Sydneykid????
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
