Hey guys,
I haven't really been on the Skyline Forums for a long time. I've been a bit financially crippled concerning car stuff.
And this is one of the reasons why.
This is my first PC build, although I don't think I've felt confused or worried at any stage, which I guess is a good sign. I've done my research, and I think it will pay off.
I'm currently studying IT at University externally, which is a massive challenge for me, but hey, bring it on.
Anyway, I felt I needed something to build this year, which I knew I could manage and most importantly afford. I also felt I needed something to reinforce my coursework, by giving me the confidence in successfully completing an intricate PC build.
I've been purchasing parts over several pays, one chunk at a time, so I've never had a set list of parts. I've kind of just winged it, with the help of PC Part Picker to confirm it will all fit.
Anyway, so far, I have the following installed:
  • BitFenix Prodigy Mini-ITX Case - Black
  • Gigabyte GA-H87N-WIFI Mini ITX Mobo
  • Corsair CX-600 PSU 80+ Bronze
  • Intel Core i7 4770k (Over-clockable)
  • BitFenix Spectre 230mm Blue LED Fan Intake
  • BitFenix Alchemy Blue LED strip
  • Antec Kuhler 650 H2O Liquid CPU cooler (Barely fit - Extremely painful to install in my setup)
  • G.Skill Ares 16GB (2 x 8GB) RAM DDR3 1866MHz
  • Corsair AF120 Quiet Edition Fans for a custom exhaust I modified for the roof of the case (See Images)
I have bought a Gigabyte GTX-770 OC 4GB, which should arrive in the next few days, and should give me a beast of a gaming experience. Managed to pick a new one up on eBay, during their 10% off discount thing for a reasonable price.
At this point, I've spent like $1700. I might be just over $2000 by the end of the build, not including a new monitor, keyboard and mouse.
All I need now is an SSD, and a HDD, which I plan on being a Samsung 250GB and a WD Black 1 TB respectively.
I also want a disk drive. Because I'm old skool yo.
Now, pictures! (Sorry if some are blurry. Haven't taken photos with my DSLR in months)
As this is my first PC build, I'd like your opinion. :)
What do you guys think?
Looks good, much better than my first build!
Some advice, I see you have it on carpet. DONT BUILD ON CARPET!
Carpet can cause a static charge to build up in you. If you touch your mobo or any other circuitry part inside you will wreck it if you give it a static shock. Seen it happen twice now. thankfully not to me. I always work on a hard floor and ground myself before going inside the case.
  • 4 months later...
Whoa, it's been a while since I've been online.
Yeah this was on a bench. Twas all safe.
Finished the PC not too long after that post with all the parts described, and a Samsung S27D590P monitor.
Pretty stoked with it.
P.S. Anyone regularly on Steam here?
  • 3 months later...
Hey Cory,
I have built a system very similar to yours. Not my first PC build but my first mini-ITX.
Bitfenix Prodigy
MSI Z97I Gaming motherboard
Corsair AX760i power supply
Core i7 4790K
Corsair H100i cpu cooler
Gigabyte GTX 780Ti Windforce OC
Corsair Dominator Platinum 2133MHz
Samsung 850 PRO 512Gb
Biggest problem I have encountered is heat buildup from the windforce GPU even though my case has the perforated side panel.
I have replaced every fan (except GPU) with Noctua fans and it is very quiet now, 5x 120mm fans total.
I will get some photos up in a day or two.
Man I have built plenty of machines on carpet (well PC on a study table) I just make sure that
A) I'm wearing my anti-static wrist strap on my ankle
and
B) just touch the case just in case to ensure that I have really grounded myself
comarcus93 - Very nice build you have there...You might want to check for clearance for a optical drive since you have your radiator up top (it's hard to tell from the pics)...
Edited by BigDirtyJase
I'm almost always touching the case when handing PC insides. A habit I developed a while back :P.
Try running a GTX 760 ITX version, only one fan and condensed PCB/small heatsink. My card hits 80°C and throttles (even at fans running full blast).
Thanks guys.
I actually had a system revamp recently and upgraded to a full ATX system running the following new components:
ASUS Sabretooth Mark 1 ATX Motherboard
Corsair C70 Military Green Case
Corsair RM-850 PSU
Corsair H100i CPU cooler
Corsair AF 120mm fans
Corsair white LED fans
+Custom sleeved PSU extensions from PC Case Gear (Military themed)
I need to change the RAM. Looks completely out of place.
AQOcfNBl.jpg?1
60rnrycl.jpg?1
yr0L1zil.jpg?1
8VMCElFl.jpg?1
Edited by comarcus93
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
