FOR SALE: (mistake in title, engine comes with turbos, apologies)
(BNR33 GTR) RB26DETT
(Power steer pump, flywheel, HD clutch and yellow jacket coil packs, stock R33 GTR ECU are available also, not included in sale)
Complete RB26dett sump to covers all intake side with standard manifolds and dump pipes, has standard injectors, standard cams and turbo's.
Removed from R33 GTR (long nose crank drive) with 120,XXXkms, has had a rebuild 15,XXXkms ago with new genuine rings and ACL bearings, and also fitted at rebuild:
N1 oil pump
Nismo multiple layer head gasket
Tomei oil restricter
Water pump, timing belt and tensioners all replaced
Nur N1 covers
All new genuine nissan gaskets used
Head Reconditioned with new retainers
Polished Twin turbo pipes
$3500
Engine has been extensively run, compression tested exactly 170psi across every cylinder and leak down tested each cylinder with zero issues. Inspections are more than welcome, feel free to message me if you have any questions.
Located Gold Coast however can freight Auswide.
0414596256
Johnny
Edited by slidinr32gtr
https://www.sau.com.au/forums/topic/443106-r33-rb26-minus-turbos-for-sale/
  • 3 weeks later...
  • 5 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
