FOR SALE: (mistake in title, engine comes with turbos, apologies)
(BNR33 GTR) RB26DETT
(Power steer pump, flywheel, HD clutch and yellow jacket coil packs, stock R33 GTR ECU are available also, not included in sale)
Complete RB26dett sump to covers all intake side with standard manifolds and dump pipes, has standard injectors, standard cams and turbo's.
Removed from R33 GTR (long nose crank drive) with 120,XXXkms, has had a rebuild 15,XXXkms ago with new genuine rings and ACL bearings, and also fitted at rebuild:
N1 oil pump
Nismo multiple layer head gasket
Tomei oil restricter
Water pump, timing belt and tensioners all replaced
Nur N1 covers
All new genuine nissan gaskets used
Head Reconditioned with new retainers
Polished Twin turbo pipes
$3500
Engine has been extensively run, compression tested exactly 170psi across every cylinder and leak down tested each cylinder with zero issues. Inspections are more than welcome, feel free to message me if you have any questions.
Located Gold Coast however can freight Auswide.
0414596256
Johnny
Edited by slidinr32gtr
  • 3 weeks later...
  • 5 weeks later...
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
