FOR SALE: (mistake in title, engine comes with turbos, apologies)
(BNR33 GTR) RB26DETT
(Power steer pump, flywheel, HD clutch and yellow jacket coil packs, stock R33 GTR ECU are available also, not included in sale)
Complete RB26dett sump to covers all intake side with standard manifolds and dump pipes, has standard injectors, standard cams and turbo's.
Removed from R33 GTR (long nose crank drive) with 120,XXXkms, has had a rebuild 15,XXXkms ago with new genuine rings and ACL bearings, and also fitted at rebuild:
N1 oil pump
Nismo multiple layer head gasket
Tomei oil restricter
Water pump, timing belt and tensioners all replaced
Nur N1 covers
All new genuine nissan gaskets used
Head Reconditioned with new retainers
Polished Twin turbo pipes
$3500
Engine has been extensively run, compression tested exactly 170psi across every cylinder and leak down tested each cylinder with zero issues. Inspections are more than welcome, feel free to message me if you have any questions.
Located Gold Coast however can freight Auswide.
0414596256
Johnny
Edited by slidinr32gtr
https://www.sau.com.au/forums/topic/443106-r33-rb26-minus-turbos-for-sale/
  • 3 weeks later...
  • 5 weeks later...
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
