hey guys .had problems with oil pressure due to bearing clearance change the bearings and now its a lil better.
now at start up i usually get around 76psi cold start blip the throttle would get as high as 90+ psi , idle is around 30psi warm hot it 22 psi.
now i have no oil mods ,no tomi oil restrictor or head drain bk. the oil pressure shots like this
1000 rpm>>22 psi
2500 rpm>>45psi
3500 rpm>>60psi
4500 rpm>>70psi
5500 rpm>>75psi
and stays 75 psi to redline (stock)
i notice everyone here has relatively high psi 90+ psi up top , but i notice they also have tomi oil restrictors does that really make such a difference in oil pressure?
even the service manual i think recommends u should see around 66psi by 6000rpm
am running a n1 pump with replacement billet gears and a custom 8 liter sup with baffles...
is it the nature of the pump to free flow at higher rpm ?
https://www.sau.com.au/forums/topic/443140-rb26-oil-restrictor-question/
Golden rule is you need 10psi for every 1000 rpm.
Oil restrictor size does little for oil pressure down in the bottom end.
What weight of oil are you running?
What clearances are you running on the bearings?
Are you running a aftermarket pressure gauge?
If its 50 weight and only going to 75 with 20 thou it sounds a bit low.
Did you check the clearances yourself or did you take for granted what the machinist said?
In my case i gave my target clearances to the machinist, got the block home and double checked it myself while mocking up everything a few times and found he was miles out on the rods but spot on the crank mains. (i found out the machinists apprentice set them up after i went back to show them or so he claims)
Otherwise sounds like oil pump shim time, which is why i used a Tomie pump, nothing beats being able to remove a cover nut and adjusting the pressure as needed.
yea could be shim time..but i have seriously long gears so even bringing down the rev to 7500 rpm i still clock 120mph in 3rd ..that trip to take down that oil pan is a bitc* ...rather lower the rev and use boost to get the hp....
oil pressure isn't all of it once i have a good flow..
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
