hey guys .had problems with oil pressure due to bearing clearance change the bearings and now its a lil better.
now at start up i usually get around 76psi cold start blip the throttle would get as high as 90+ psi , idle is around 30psi warm hot it 22 psi.
now i have no oil mods ,no tomi oil restrictor or head drain bk. the oil pressure shots like this
1000 rpm>>22 psi
2500 rpm>>45psi
3500 rpm>>60psi
4500 rpm>>70psi
5500 rpm>>75psi
and stays 75 psi to redline (stock)
i notice everyone here has relatively high psi 90+ psi up top , but i notice they also have tomi oil restrictors does that really make such a difference in oil pressure?
even the service manual i think recommends u should see around 66psi by 6000rpm
am running a n1 pump with replacement billet gears and a custom 8 liter sup with baffles...
is it the nature of the pump to free flow at higher rpm ?
https://www.sau.com.au/forums/topic/443140-rb26-oil-restrictor-question/
Golden rule is you need 10psi for every 1000 rpm.
Oil restrictor size does little for oil pressure down in the bottom end.
What weight of oil are you running?
What clearances are you running on the bearings?
Are you running a aftermarket pressure gauge?
If its 50 weight and only going to 75 with 20 thou it sounds a bit low.
Did you check the clearances yourself or did you take for granted what the machinist said?
In my case i gave my target clearances to the machinist, got the block home and double checked it myself while mocking up everything a few times and found he was miles out on the rods but spot on the crank mains. (i found out the machinists apprentice set them up after i went back to show them or so he claims)
Otherwise sounds like oil pump shim time, which is why i used a Tomie pump, nothing beats being able to remove a cover nut and adjusting the pressure as needed.
yea could be shim time..but i have seriously long gears so even bringing down the rev to 7500 rpm i still clock 120mph in 3rd ..that trip to take down that oil pan is a bitc* ...rather lower the rev and use boost to get the hp....
oil pressure isn't all of it once i have a good flow..
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
