Today my 1999 S2 Stagea (RS4S) hit 100,000 kms, and it was kind of upsetting. It made me feel like the car had graduated to the next age of car life.
But then I realised, this is a ~15 year old car, it must be going pretty well to only be hitting 100,000 now. Right?
So tell me, how many Kms has your Stagea done?
100k club?
200k club??
or a special garage dwelling <50k?
https://www.sau.com.au/forums/topic/443149-how-many-kms-has-your-stagea-done/
100k club?
200k club??
Just get speedo wound back as per most jap cars....
Edited by Ben C34
78,000km ('04 PNM35), and from the condition I'd say they're genuine. Still had some factory plastic protective film in places when I got it, I don't think anyone ever sat in the back.
96 model, 130k kms. Can't be sure if it's genuine. Some doubts for me are that Ive replaced the turbo. It wasn't blown but had too much shaft play. Front shocks were totally worn by 100k kms on the odo, which Im not sure if its normal since it's a heavy car with sporty shocks. Maybe too much wear on the drivers seat too. No point dwelling on it. Its running well and is in good condition now.
Just over 300,000.Killeran, I'd suggest getting Japanese History Check to prove your KLM, I think its very unlikely a car has done under 7,000klm per year every year of it's life...
I think many of the answers here would be ???,???kms.
It's been endemic in the industry for a long time.
  • Like 2
98 rs4, bit over 228000kms, pretty good condition, it's had a turbo at some point before I bought it, only engine repairs I've done are timing belt and all front seals and water pump. Heaps of stone chips and some rust under the mirrors.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
