Looking For A E85 Map For A R32 Gtr Nistune
Seriously?
Take it to a tuner and start from scratch. How does anyone know what your setup is.
Injector size, comp ratio, turbo(s), AFM size.
IBTL!
Once I get it dyno tuned. I'll gladly share my map to help a fellow GTR owner. Not everyone is a D-Bag. Plus I'm in the US, so we've only just been able to get the 1989 R32 since Jan. It's almost impossible finding someone familiar with them.
I have z32 mafs, 1000cc injectors, 450/lph fuel pump, tomei FPR, R34 N1 turbos. If I can get a decent e85 base map I can street tune for now until I can get to a dyno with a tuner familiar with nistune.
Well here's the deal. I'll assume you have the software and the license, because if you don't you're not being forward thinking enough. On that basis, work out the K factor for the bigger injectors and the AFM, add 30% for E85, don't touch the timing. Fiddle the K factor (and the injector latency) until you get it to start and idle. Ideally check the mixtures at a light cruise with a wideband. Then drive it really gently to the tuner.
You will NEVER get a pre-done tune that you can just load up and drive merrily off to the tuner on. At best, even if beautifully mapped by the world's best 26 tuner, it will as like as not never even start unless you can adjust the basic scaling values yourself.
  • Like 1
Exactly.
Not sharing a map doesn't make someone a d-bag. It goes to show they understand blindly sharing a map isn't actually helpful.
Download the Nistune tuning guide pdf from their website. You're looking for the sections on how to recalculate k to account for both AFM changes and also injector changes. You need to read and understand that stuff, as if you were going to do it yourself, even though there is a built in function in Nistune (software) to do it for you nowadays. The reason you need to know is that you will probably get Nistune (software) to do it for you for the physical changes, but you will need to know how to then mod that number to account for E85 (ie adding that 30% extra fuel).
Short answer, you make k 30% bigger just to account for the fuel change.
If I were you, I would definitely read the Nistune forums also, with respect to looking for specific instances where people are just converting to E85. There's probably a few extra tidbits hidden in there about what extra things you will need to do and which extra things you might do won't help. That sort of thing.
  • Like 1
Thanks that info is awesome and just what I was looking for. There's only one nistune tuner in the entire state of Texas so most help I get is from the GTRCanada forums. Since there are only about 2 or 3 E85 stations in Canada, there is not much help for tuning for it.
 Share
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
