Hi guys,
Interested in your opinions on the teeth of the below starter motors.
The starter on my S2 R33 has been getting pretty lazy for a long time now. Its part number is 23300 08U15. I am running a Cusco chromoly flywheel but I doubt this affects anything.
Pics of the starter motor 08U15 I removed are attached and marked "original starter".
I obtained a second hand replacement from a friend (labelled "new" in the images), which was removed off his RB25 (S1 however). Part number is 23300 08U10. The unit itself on the outside is identical, solenoid position etc all match.
Inside they are slightly different re the number of magnets etc - but I am not concerned with that. My concern is the teeth which engage to the ring gear are completely different. I counted 15 on this unit, but not only that, the circumference of the teeth appear to be a lot smaller.
I have read that all RB starters are interchangeable - I simply want to check that, against the images contained within.
I note I didn't find another thread with pictures like this.
Anyone have an opinion on whether the different teeth with affect engagement with the flywheel? Hoping to bolt the new one back in tonight and I don't want to do any damage!
https://www.sau.com.au/forums/topic/443153-rb25-starter-motor-comparison-halp/
As long as the teeth are the same height (each, tip to base of tooth) and as long as the outer circumference of the teeth is the same distance away from the line running through the mounting bolt holes, then the teeth will happily and merrily engage in the teeth on the flywheel. The different number of teeth is more than likely a result of the different motor configuration (number of poles basically) and compensates for the different speed of the motor.
So measure up the engagement depth of both gears relative to the mounting bolt line and see what you have. Given the well reputed interchangeability of RB starters, I would hazard a guess that you will find them to be the same.
  • 8 months later...
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
