Hey guys need a low profile jack, struggling to find a good one though. Originally wanted the Arcan one from Costco but it's looking to be impossible to find now.
I came across this, what do you guys think?
https://www.sau.com.au/forums/topic/443166-low-profile-jack/
3000kg is good, but it also weighs 36kg so its definately not a light weight jack that you can easily throw in the boot of the car to head to the track. One of the great things about the costco jack's is that they are light weight enough to carry around with one hand if you wanted to.
i got one of these recently
http://www.ebay.com.au/itm/TORIN-BIG-RED-JACKS-2-TON-ALUMINIUM-HYDRAULIC-TROLLEY-RACING-JACK-LOW-PROFILE-/350707460075?pt=AU_Car_Parts_Accessories&hash=item51a7cb27eb
its works well and seems well made
they shipped quickly and had no dramas, also comes with a warranty
People like Birds may be re-selling costco ones on ebay, search for Arcan 1500kg, I know I did, just don't have the history of it as it was ages ago. Remember checking at the time and the price was there/thereabouts especially considering the faff of getting in to costco.
i have a jack similar the one posted at the start, if your car is low the higher part of the jack can get stuck on sway bar etc yet the lower part will be able to clear the crossmember but wont reach it due to being too short in length.
so size does matter guys :)
My current one is strong, but stupid heavy... Its not low enough to go under my front bar and reach in far enough to get to the cross member... I need to drive the car up onto little wooden lifter ramps first, pain in the arse :(
Are the costco ones long enough that you can reach the cross member in the middle and still have room to actually move the jack handle under the front bar?
Tempted to just buy a cheapy one, then I can throw that under a tow point on the front to lift the car just a little bit so I can get my main jack onto the crossmember without any hassles. Just sucks balls when you've only got one jack and the car isn't running for some reason and you need to get the front up... Currently it's this weird unsafe dance involving jack stands in weird places so I can reposition the jack, blergh.
Now we're going in a different direction... First you wanted a low profile jack... now you're going for a light weight one which can only hold 1000kg, with a 375mm maximum lift height (not much compared to the original 505mm one you posted) and it doesn't look low profile at all...
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
