Rb20Det Engine Nsw
https://www.nengun.com/hks/valcon-rb26-v-cam-system no controller but most will use ECU to control anyhow
Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
Yeah good point, it won't flash on indicator that way, so plan B, just another wire to run from under the dash which makes it a bigger job 30 to indicator + globe side 86 tapped into 12v input to flasher relay under the dash (has 12v when indicators on, nothing when no indicators) 87a to headlight parker + 87 to original indicator + chassis side 85 to chassis/earth Now it will flash with indicators and be solid on with parkers
