Hi guys considering doing the smart thing and bailing on my build considering things have changed in my life
I will only be parting once I get the big items pre sold shell engine box
R34 gtt Stat write off can't be rego'd shell had a front end smack pulled straight rad support not mint needs a bonnet, sus and wheels to roll $3,000 ono
(not interested in your thoughts as I've spent a fair bit to get it looking ok again)
25 neo engine no ecu or injectors $1500 proven running motor not some wrecking yard unknow can be comp tested by buyer if needed
34 25 5 speed box $1500 firm
ORC pull type twin plate clutch $750 firm
HPI R34 Alloy Rad $280 firm
Blitz return flow intercooler brand new in the box $500 firm
r34 gtt fcon ecu and patch loom tuned for cooler and exhaust round 220rwkw atm (info from prev owner) $400 ono
cat back exhaust unknown brand $500 ono
Chinese r33 front pipe brand new $80
Chinese r33/4 dump pipe brand new $50
Kando brand new external gate T67 $850 firm
Kando rb bolt on TD06H 20g internal gate brand new in the box $750
K sport R34 gtt coilovers $600 firm
r34 gtt nistune $500
Turbosmart 45mm gate brand new in the box bought from mtq so legit $385 firm
walbro E85 450l pump brand new $150 bought from mtq again
ev11 or whatever 25 neo 1000cc injectors fitted but not fired again brand new from mtq $550 firm
feel free to mesg me if you have questions
if I don't get what I'm after I'll just put it on the back burner
041
1152
733
Edited by 1400r
If you don't mind me posting up Ryan I've got the triple gauges for the other member.
Also have a mint front section that was cut off my car and ready to go on this if anyone wants to fix the rad support etc properly.
  • 3 weeks later...
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
