Hi all, I've searched and searched but haven't found an answer that helps me!
BIt of leading info, built an rb30det (untouched bottom and pre vct untouched head), popped a head gasket (cheapy) pulled engine out and gave it a fresh set of rings/bearings and seals, got head reco'd (cut/grind valves and face head)
Put all back together and had noisy lifters,
I put up with it for a while as only a few, say 4 or 5 where ticking,
Finally had the cash to buy new ones and did all the stuff ya do to install them, soaked in oil for a week before hand, put em in and run them up to speed to run them in to the cams, used comp cams grease when installing,
All good but they still are noisy, and it's all of them! Knock is over 117 at idle on my pfc.
Took it for a drive, still no good.
Pulled my cam covers thinking maybe the valves where ground too short? And they had minimal to no collapse against the cams, but I can't even fit a 0.05mm feeler gauge under between cam and lifter on any.
So they are pumped out, plenty of oil to the head, as its full up everywhere and I didn't fit any restrictors in the block. All looks good but sounds terrible!
Please help as its doing my head in!!!! And can't go for a tune with all this head noise, (engine head not mine!)
Cheers.
Just dropping the new lifters into an oil bath probably wouldn't have done much.
Making sure they were collapsed before installation would be the way to approach things. Use soft jaws in a vice, and maybe a short bolt to get the load where you want it.
Could be that your oil spec is hindering efforts to have them self bleed.
And yes I read the comment that they are bled, but if they're tapping, they're not bled. HLA are zero clearance.
Edited by Dale FZ1
By design they should bleed during operation, my previous builds have done when started,
Massive noise on startup then silence 20-30 sec in.
I'm pulling them back out and going to see if the valve actually checks or if they are just pushing in and out.
If they're not I'll clean and install my old ones.
Edit. Today I drained my 10-30w and filled up with 20-50w but it didn't make much difference.
Edited by nicksamaniac
Yeah I soaked mine in petrol and pumped them, cleaned them up then did the same in oil, left them for about a week before the head went back together. Have had no issues
If your oil pressure is ok then sounds like its a fault with one or more lifters (if it is the lifters)
My injectors are quite loud on initial startup and can be confused with lifter tick
I build a 25 and only after I beat the car hard does my lifter start to make noise. It sounds like 2 of them are bad. What I want to know is how can I find out which ones are the bad ones. ??? It's a fresh engine with new oil pump and the pressure is good.
Well I spent about 7hrs today disassemble-cleaning-reassemble all my original lifters,
Now they're all freely moving and looking nice, lapped all the mating surfaces.
I'll remove my new ones and fit the originals tomorrow. post-92047-0-10892400-1400395153_thumb.jpgpost-92047-0-68722200-1400395168_thumb.jpg
Well here is some truth for peoples knowledge,
I installed all my old lifters yesterday, completely dry apart from a tiny bit of oil used to assemble them.
I couldn't bleed the valve before assembly because it wouldn't fit back into the body (made it to long for the clip to go inside the lifter body)
So I assembled them dry, (smeared with oil) and fitted them without soaking in oil, and they all bled up with 10-15sec of starting.
It's now super smooth running, this proves that they do bleed during operation, (by design, oil must fill the body -then the valve itself and pump the valve out and bleed out of the center to the cam lobe).
No, non-genuine i bought from a store in Queensland,
One of them actually had come apart as I removed it, the valve fell out of the body when I lifted it up!
The clip was all mangled. I showed a few mates and no body had seen it before, and found 4 that would not check even though they where full of oil.
No brand name but was told they'd had excellent results from them over 1000's sold.
So I don't know? But I'm not going to keep them, hock them off or send em back.
Or just bin them, they're obviously no good.
We'll I've used non genuine lifters in all my other builds, (mostly holdens, 305 and 355 I've built) and never had a drama. Genuine Nissan is a rip off, they must be made from material from Saturn? Cos the price reflects as though it is.
This is why I dont use aftermarket lifters anymore:
This was in my old VL, rebuilt engine, everything was new. This happened after about 3 weeks of driving
Not saying all aftermarket lifters are bad, but its just why I'm careful with lifters. I was real lucky the bits didnt pic up on one of the cam lobes because where they were sitting in the head, it was really suprising that they didnt
I don't really want to name and shame the store, they've been really helpful and have given me a full refund,
He said he's going to return them to the supplier to check them out.
Also they do sell some really good stuff for import cars.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
