So due to some personal shit,
RB30/25 long engine. Approx 3000km since finished run in.
Nitto H beam rods with built in oil squirters
JE pistons 20 thou over
JUN oil pump
checked and balanced crank, nitto crank collar fitted
Nitto 1.2mm drag head gasket
Tomei oil restrictors
RB25 cylinder head, full recondition VCT blocked off
Kelford 272in272ex 9.35mm lift camshafts
Performance Springs 10mm lift valve springs
Lightly ported intake ports.
HKS cam gears
RB25 power steering pump.
twin -12 block breathers
RB26 rocker covers, with nitto clear front cover, painted pink with 34GTR centre plate and twin -12 outlets
Nitto -10 rear head drain and braided line into block
water ports bunged up with NPT fittings
alternator and thermostat housing included. No manifolds.
Made 522rwkw at 26psi e85
$7500
Greddy intake plenum genuine, with all bolts, Q45 throttle body. perfect condition.
$900
6 boost steam pipe manifold, suit RB25 head. t4 split pulse flange. Borg Warner SX366 turbo, 45mm Vband gate, manifold has EGT sensor ports, as does turbo rear housing (can buy blank offs if not required) 3.5 dump pipe to suit, screamer pipe to suit, -10 turbo drain and fittings. -4 turbo feed and lines.
$2000
Stainless steel 3.5" catback exhaust. slip jointed rear. to single 4" tip. good condition.
$400
HKS fuel rail, -6 twin entry, single -6 exit. speed flow lines to suit. 1650cc bosch injectors, all flow tested perfect. all O-Rings to suit. will suit RB26 and RB25 with suitable mounts.
$900
Splitfire coil packs suit R34 Neo (fitted to S2 R33 atm) less than 500km old.
$450
HKS oil cooler kit. black braided lines, purple HKS fittings, HKS core, HKS thermostat adaptor for SR20/RB25/RB26
$500
KOYORAD N Flow radiator, suit R33, bung in top port for 1/8NPT water temp adaptor. only ever run with redline water wetter. good condition, no leaks etc. HKS radiator cap
$450
Bullion power steering resovior. billet.
$150
Stainless steel overflow tank. $100
Custom alloy catch tank. 4 -12 ports (2 for block, 2 for head) all speed flow to suit (black on black)
$500
Aeromotive fuel regulator. -6 in and out. red colour. 1:1 ratio.
$180
Haltech PS200, custom loom for RB25. 5 bar map sensor, intake air temp sensor, oil temp sensor, oil pressure sensor, stand alone harness with fuse box incorporated.
$2250
Haltech Wideband AFR CAN kit. brand new, used for one track day. all sensors+wiring
$350
Haltech EGT sensor setup. CAN TC4A and TC4B boxes, 6 sensors. all can cables etc
$850
Haltech CAN hub. required for more than 1 can device.
$150
Haltech Racepak Dash, latest version. can cable to suit.
$900
Gforce T101A 4 speed dog box. from nascar. Ratios: 2.69, 1.61, 1.29, 1, LONG side shifter correct setback for nissan trans tunnel, Custom RB bell housing, Custom twinplate clutch from Direct clutch services, Quarter master concentric slave, TH400 output, GM26 input, Strange billet yoke. Will be freshly rebuilt on sale, straight cut gears, dog engagement.
$6500
GTR diff. 4.11 ratio, ATS carbon adjustable 2way centre, GTR drive shafts, GTR hubs to suit. Greddy extended Diff cover. -6 diff breather outlet with speedflow breather line.
$1800
R34 NA rear cradle. bare, non hicas, with subframe risers
$200
Rear drop knuckles. modified for twin calliper (nissan 2 spot callipers)
$350
Ikeya formula Camber, toe and traction arms. Suit S14/S15/R33/R34 (non hicas)
$500
Ikeya formula front lower control arms, suit S14/S15/R33/R34, built in castor arm, roll centre correction etc
$500
Cusco front upper arms, suit R33/R34 adjustable camber, pillow ball design.
$200
GP sports Gmaster coilovers. Suit R33/R34na perfect condition, no leaks/knocks
$1200
mitchy knuckles, R32/R33/R34
$250
Ikeya formula adjustable tierods, new nissan tie rod ends.
$200
R32 cross member with rack moved forward.
$150
Work VS KF wheels. 18x10 -4 chrome on chrome. new Kumho KU39 245/35 tires R disk (clear big brakes)
$1500
Work VS KF wheels. 19x11 +20 chrome on chrome. new 265/30 rotalla tires. 0 disk (maximum dish)
$1500
Work VS KF wheels. 19x10.5 +14 chrome on chrome. new 265/30 rotalla tires. 0 disk (maximum dish)
$1200
Work VS KF wheels. 19x10.5 +14 chrome on chrome. new 265/30 rotalla tires. 0 disk (maximum dish) require some polishing to get up to shine again.
$1000
R32 GTR brake set. rebuilt front callipers, Endless front and rear pads. 4x rear callipers (for dual calliper) DBA rear rotors.
$1000
Wilwood twin pedal box, reverse mount, with 3x master cylinders and braided brake lines from box to callipers
$500
Stewart wilkins hydro handbrake, upright model, wilwood master cylinder with resovior.
$300
Aeroflow surge tank, twin 044 pumps, all mounts and lines to suit.
$500
Nardi deep corn, black centre, perforated leather, red stitching.
$250
Bride Vios 3 lowmax, perfect condition, no rips or tears. genuine, comfy
$450
Bride seat rail, drivers side, side mount.
$250
R33 Ganador Mirrors, painted silver, electric
$350
R33 series 2 carbon bonnet, painted silver. MASA custom, hard to find.
$500
R33 series 2 headlights. not yellowed and shit. good condition, have HID kit.
$350 pair
R33 GTR series 3 front bumper, lip has some damage, bar has indicators and mesh, carbon cannards N1 vents.
$500
R33 GTR boot lid with wing. good condition, no damage.
$300
Beat up R33 PS Duce body kit. Sideskirts and rear bumper only, most pieces there to repair. genuine kit.
$350
R33 URAS sides and rear, previously repaired, painted silver, good condition.
$300
R33 roof spoiler, painted silver.
$200
Series 3 GTR bodyshell, compliance tags, modplated for Engine, gearbox, cage, seats, harnesses, fuel setup, etc. No outstanding defects, currently unregistered, full weld in cromoly cage. side intrusions, through the dash, race car rewire, all glass, working window motors, tinted rear windows, Modified to suit 2wd front crossmember. front tubbed for extra lock. Boot floor cut out for fuel cell. Tunnel modified for big gearbox.
$1200
VE SS commodore coilovers. XYZ brand. good condition. (ute if it makes any difference?)
$1000
VE SS hubs modified to suit 5x114.3 stud pattern. come with brakes to suit.
$1000
Contact VIA SMS only on 0427282562.
All parts located in brisbane. Can arrange postage at buyers expense.
  • 3 weeks later...
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
