Hey guys I think I'm up for a new engine. Here's why:
I installed an oil temp gauge as I was looking to do some laps at wakefield soon and before going through the hassle of installing an oil cooler I wanted to see if it was 100% necessary.
Anyway I already had the sandwich plate so I installed it with a fresh oil filter and topped up the oil about 10 days ago. I didn't check for leaks (like a dumbass) because i've used this plate twice before on multiple cars and never lost a drop, didn't even cross my mind.
I drove about 250kms in the past 10 days so not heaps but yesterday arvo I started it up and it's rumbling and shaking all over the place so I shut it down. checked the oil, sure enough it took almost a full bottle of oil before reaching the full indicator. I reached under the oil filter and there was oil on the bottom side of it.
I didn't have time to go over it properly.
I drove it to the station this morning and the issue didn't go away or get worse in the 10-15 minutes but I kept revs well below 3k. I know I know it shouldn't have been driven but if it's truely f**ked I'd rather swap out a healthy motor than pull mine apart and rebuild.
What do you guys reckon? If it was a spun bearing would it even start?
If anyone is in the area I would really appreciate if you could drop in and check it out, 2nd/3rd opinions are always a good idea. I live in the north shore area of Sydney.
Cheers
edit: Also just wanted to mention that in that period I never hammered it, barely boosted at all since installing the gauge not that it really matters
also forgot to mention my setup. Hypergear 21U highflow on E85 300ish rwkw (was wheelspinning on the dyno due to semi slick tyres). standard RB25det R33 motor. Z32 nistune/afm 1000cc sidefeed shithouse FIVEO injectors
Edited by Blackkers
What is a bottle of oil? 5L? 2L
If necessary I would pull the engine apart before buying another. it could be relatively cheap to repair as opposed to buying another unkown quantity.
You'll find if it has spun a bearing it won't be magnetic material (mostly) as bearings are made from white metal, like zinc, tin alloys etc, very soft material.
It will show up in the filter if you cut it open, and your dropped oil will be very sparkly/metallic looking.
Edit, unless it's spun so much you have removed the bearings completely, and it's rod against crank etc, then it will show alot of magnetic junk! But youd know it if it got this bad, you would shut it down due to the catastrophic noise it makes!
Edited by nicksamaniac
  • Like 1
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
