hi everyone i am having a problem atm with my r33 gtst rb25det it has been a problem since i have owned the car even after i have swapped motors.
when warm or cold as coming onto wot the car surges from 2000rpm to about 5000rpm then after that it completely frees up.
its a bad surge and if i hold wot when it surges it back fires and sounds like there's a front fire ?
standard boost well standard setup,
has front mount.
i have got new plugs gapped at .8
and have swapped coil packs no difference at all
timing is at 15 degres and the more timing i give better it gets
also has a new walbro hp fuel pump cant remember what models was good for 300 hp tho.
but when car is running or fuel pump is primed the fuel line isnt hard hard i can push it half way in .
any ideas on what it is guys all help much appreciated ??? thanks for reading :)
https://www.sau.com.au/forums/topic/443331-r33-gtst-rb25det-surging-help/
Checking the hardness of the fuel line won't tell you anything, that's what a fuel pressure gauge is for.
Obvious things to do are clean afm and check for boost leaks.
Aren't you the guy with the rb20 turbo that glows red all the time, drives hard everywhere and just got car out of impound?
If you are at all concerned about low fuel pressure......then why not either install a fuel pressure gauge into the line or take it to a mechanic who can so you can see if there's a problem or not?
yes that is me. i have started to drive normal now thanks to the new hoon laws i just want car to run good thats all
y
Are you sure you checked the timing right? Did it with a plug lead between cyl 1 spark plug and coilpack and then put a timing light on
Sounds like timing to me, especially if it gets better as you advance it
Is the CAS dead?
Of course I would agree it could possibly be the afm as I already suggested that.
and also i took the rod off the actuator and its runs smooth as f**k obviously no boost ? so what do u suggest there? i have put a afm and borrowed a cas still the same ?
