When I first bought my 32 I wanted to do the 34 seat swap I looked everywhere even on here and could not find a good tut a found one web site that said straight bolt on but one bolt and still did not explain about the rear so I want to share a little..
If you are thinking about doing the swap the front seats will bolt on but you will need to grind off the top left(top right for passenger) mount and get an extended mount professionally welded on to reach the hole for the bolt,
With the reads the top half of the seats will go on with a small bit of force but the reads need a bit of modifications you need to make a new hole for the bolt to go into because the rear bottom is longer then the 32 seats so the old thread hole can not be used.
I have not yet got around to making the new hole but when I do i will post instructions.
(Modifications to seats may not be legal of not engineered but the state so be careful)
https://www.sau.com.au/forums/topic/443335-r34-seats-into-r32/
  • 4 weeks later...
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
