Hi all, i have an R32 GTSt thats hunting at idle, i took it to a shop and after an hour we traced it to a faulty AACvalve/IAA unit, we swapped mine with a known working one and it fixed the problem, so i tried cleaning mine (fair bit of carbon build up), which didnt fix the problem, so i bought a second hand one form a wrecker, installed it, and the problem was still there, i then reset the ecu as i thought maybe it was "ignoring" the faulty sensor, but this didnt work, i then adjusted the idle to about 2 grand and the "high revs" part of the cycle went for longer, but stilled dropped and fluctuated,
My question is, has anyone had a similar problem and how was it fixed, or does anyone have a suggestion as to what it could be? or is it possible that i was sent a dud IAA?
cheers
https://www.sau.com.au/forums/topic/44334-hunting-at-idle/
Try this:
Did you clean the one from the wrecker or was it cleaned by them?
Have you tried unpluging the AAC valve to see if there is any change in idle stability after warm up? If idle stabilises then the AAC valve is Dirty or a faulty one.
Make sure the plug is making good contact or has clean terminals on the AAC valve.
Check wiring for breaks/corosion.
If all else fails then you have two faulty AAC valves. :cheers:
Also these will affect/help idle stability: (for any one else with idle problems, not really your problem)
Check air/fuel ratio's (do a fuel pressure test aswell)
Check ignition timing.
Clean the AFM.
Check vacuum lines and blow by hose.
Check for air leaks in intake pipes.
Basically the idle is controled by the AAC valve after the motor reaches operating temperature, when the motor is cold the valve is closed.
Other factors that affect idle stability after warm up include air/fuel ratio, ignition timing, misfire or in a worst case scenerio cyclinder compression.
Edit: Also the ignition timing, idle speed and CO and HC density (Oxygen sensor) are all inter-related, adjusting/changing one means that you'll need to check the others.
MEGA
https://www.sau.com.au/forums/topic/44334-hunting-at-idle/#findComment-906385
Try this:
If all else fails then you have two faulty AAC valves. :rofl:
MEGA
thanks for the reply, i already tried the things you suggested, but none of them fixed the hunting, although when i disconnected the AAC valve (plug) it kept hunting, ill have to find another one to try i guess
https://www.sau.com.au/forums/topic/44334-hunting-at-idle/#findComment-907897
But.... it must be the AAC valve if you said it fixed it once before with the borrowed working one?
The reason that the hunting continued after the AAC was disconnected could be because the valve or spring is binding/seizing in the housing and is making the valve fluctuate causing the unstable idle.
When is it unstable? (All the time or only after the engine warms up)
MEGA
https://www.sau.com.au/forums/topic/44334-hunting-at-idle/#findComment-908042
If it isn't seized or fouling anywhere then you can check the solenoid part of the valve with a multimeter.
There should be 9-10 ohms resistance between the two terminals on the AAC valve.
The plug side (eccs control unit side) is measured in volts and needs to be measured between terminal 1 and ground and it will be:
The plug should look something roughly like this:
[.1.I.2.]
Ignition switched on: battery voltage
Cranking engine: 2 to 3 volts
Idle when cold: 6 to 7 volts
Idle when warm: 8 to 10 volts
Sorry I couldn't be more helpful, if you lived in my home town I would try to fix it for you.
Edit: I have attached a pic of idle adjustment info. (sorry about the quality)
MEGA
https://www.sau.com.au/forums/topic/44334-hunting-at-idle/#findComment-908197
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
