Hey guys got a set of TE37 17x10 +18, no tires
PCD 5x114.3
These came off my brothers R33.
They are all in great condition expect one curbing shown below. Other than that they are pretty mint for their age.
They will also come with brand new genuine TE37 decals in black to replace the old ones.
Price: $2,600
Please PM for further info.
Pick up or can ship at buyers expense, usually $60 for Australia wide.
Thankyou for reading.
https://www.sau.com.au/forums/topic/443349-vic-te37-17x10-18-bronze/
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
