Hi mates I want to get some bearings for my turbo. The size I need is 26x10x8. Does anyone know where I can get them? My local bearing shop only had one the said was rated to 12000 rpm but when I googled it it was actually 36000 rpm in oil.
What speed do they need to be good for?
When you get shaft play is it from the bearings?
Bearings are the least of your dramas. How are you re balancing your turbo? 1/4 of a gram gets VERY heavy when you spin it quickly! What turbo is it for? Most modern garretts are non rebuildable. Most are only available as a core (bearing, housings turbines etc, pre build, pre balanced)
If you need bush bearings, then I can get them easily through a local turbo supplier.
Shaft play which way? in out or up down?
You can't. Garrett make it very hard and or expensive to get replacements. That's one of the reasons the GCG rebuilds are so expensive. Try Hypergear - he will know if they can be got.
I wouldn't try rebuild it. Balancing is the main issue. As for the speed. 150k to 200k more than that is over spinning your turbo. Danger will Robinson danger. Lol
Edited by MJTru
During the VNT CBB development the shaft speed of the SS2 Alpha have maxed out the gauge of 180,000RPMs around 5000RPMs, so by the end of the run of 7200RPMs it would be over 200,000RPMs.
The 12,000RPMs bearings don't work, they could be easily obtained, those were the first ones I've tried and Very nosy.
Apart from balancing, and shaft speed there are many other critical areas to be considered. It took me close to a year to workout all aspects and having it working reliably.
Yeah I've only ever rebuilt turbos for large diesel engines which only rev to about 2100rpm, and they were pretty heavy duty bush bearing turbos. Fair bit of screwing around getting everything right on the shaft then balancing the thing. This is why I gave my original comment. If he can't source bearings, I dont know if I could trust the final build of the turbo
Talk to Stao ^ ^ ^ ^ ^ ^ ^ ^
He definently knows his stuff, plenty of happy customers on here, myself included
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
