Has anyone tried an extended rb26 oil pan from Rob at RaceFab.
I just paid for one and was wondering what you guys think about it. Here in the USA we have team Raw Brokerage that builds oil pans for rb26. But like kyle from 6 Boost I thought I would trust in Rob to build a good unit for me. In doing so I can garranty sales from the USA and Caribbean countries either through me or direct.
Any comparisons would be helpful until I receive my unit. After arrival in take close photos of both and we all can make comparisons.
https://www.sau.com.au/forums/topic/443377-racefab-oil-pans/
I use one of these from Performance Metalcraft in Rydalmere. I dont know what they retail for but they can be made to whatever spec you want. Ours is a 2WD so the diff is removed and holes plugged
and most of them leak due to using a porous alloy
I've got one. As per DCEIVE I haven't used it yet but it's a brilliantly made piece of kit.
Rob is a top bloke and easy to deal with.
The $150 each way in freight for a big heavy bulky sump is a killer but still a lot cheaper than anything locally (unfortunately).
Rob can build it exactly how you want it. I added numerous -10 fittings and an external oil pick up. The welds are AMAZINGLY good.
Yes Rob sent me a photo of the one he build for me. It looks great and can't wait to see it in person. If I'm happy with the work I'm sure I'll buy another and a friend of mine wants one for his r32 gtr
    • Agree with Rob. I recently did mine and replacing with a brand new unit made the most sense compared with rebuilding my existing gearbox.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
