Has anyone tried an extended rb26 oil pan from Rob at RaceFab.
I just paid for one and was wondering what you guys think about it. Here in the USA we have team Raw Brokerage that builds oil pans for rb26. But like kyle from 6 Boost I thought I would trust in Rob to build a good unit for me. In doing so I can garranty sales from the USA and Caribbean countries either through me or direct.
Any comparisons would be helpful until I receive my unit. After arrival in take close photos of both and we all can make comparisons.
https://www.sau.com.au/forums/topic/443377-racefab-oil-pans/
I use one of these from Performance Metalcraft in Rydalmere. I dont know what they retail for but they can be made to whatever spec you want. Ours is a 2WD so the diff is removed and holes plugged
and most of them leak due to using a porous alloy
I've got one. As per DCEIVE I haven't used it yet but it's a brilliantly made piece of kit.
Rob is a top bloke and easy to deal with.
The $150 each way in freight for a big heavy bulky sump is a killer but still a lot cheaper than anything locally (unfortunately).
Rob can build it exactly how you want it. I added numerous -10 fittings and an external oil pick up. The welds are AMAZINGLY good.
Yes Rob sent me a photo of the one he build for me. It looks great and can't wait to see it in person. If I'm happy with the work I'm sure I'll buy another and a friend of mine wants one for his r32 gtr
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
