Hey guys just a couple of quick questions. Should I buy a back up computer for my stagea and get that done by nistune. I haven't delt with nistune before, how long do they usually take to install and get my ecu back to me. And finally once I have it installed how hard is it to sell my current ECU. Or does anyone have a nistuned ECU for an auto s2 c34 that they want to sell????? ;)
https://www.sau.com.au/forums/topic/443401-nistune-ecu-options/
Thanks for the info. I have checked out the nistune site and read every page 5 times hahaha. I just don't know all the little things like what sort of turn around time they have, how accurate the base image/tune is. What I am really trying to find out is should I buy another ECU send that to nistune, get all the other bits and pieces together then get it tuned. Or do I get the nistune done with base tune to the mods I already have then upgrade tune on dyno with a tuner. I was thinking about using Just Engine Management in ingleburn to do the final tune.
Nistune won't give you a base tune to suit your mods.
It will be exactly the same as stock once the Nistune board is installed.
Then the tuner can change the map to suit.
Nistune don't tune cars. They make and sell the hardware and software so cars can be tuned.
Thanks Ben, that is exactly what I needed to hear.
Currently only have pod filter, splitfire coils, 3" turbo back exhaust, radiator air deflector. As for the power goals I don't want too much more but was thinking hi flow turbo, nistune. If I have to maybe injectors and fuel pump if needed.
It is time to take a deep breath and work out what you really want from the car before making the next step.
If you are making the jump to modify then you will most likely need a FMIC, boost controller, Nistune, hiflow turbo or decent aftermarket, decent catalytic converter, fuel pump and bigger injectors.
If you are prepared to live with the stock turbo you can leave out the bigger injectors and possibly the fuel pump but I would still make sure the rest is done.
Take your time deciding because every time you change your mind it costs more money to R&R parts and then you need to pay to retune.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
