CLOSING 14/07/04 (very soon!)
Hey guys,
Will go for one more group buy as it seems there is still a bit of interest around. Have managed to get some prices on some more bits this time so all is included.
Like last time, will make order when all payments have cleared... need a min of 15 , so shouldnt be a problem. Can pay via direct deposit (easiest way) or money order etc.
[email protected]
--> prices & pics here <--
INTERIOR:
Chrome Alloy Gear Knob - $105
Black Alloy Gear Knob - $105
Leather Gear Knob - $70
Carbon / Alloy Gear Knob - $110
Titanium - $215
GT Urethane - $85
GT Titanium - $210
Black / White Racing Plastic - $70
Blank Key - $65
Racing Fashion Lighter - $40
Horn Button - $45
EXTERIOR:
Clear Side Winkers (S15, R33, R34) - $70
Clear/Smoke Front Winkers (R34) - $135
Carbon Wing Garnish (R33 - Nismo / GTR) - $110
Carbon Wing Garnish (R34) - $165
Carbon Pillar Garnish (R33 / R34) - $140
Carbon Pillar Garnish (R33 4 door) - $270
Air Valve Cap Set - $55
License Plate Bolt Ornament (Black / Silver) - $35
ENGINE:
Low Temperature Thermostat - $110
Iridium Spark Plugs (6) - $170
S-Tune Air Filter - $125
Oil Filter - $40
Oil Cap (Old Style) - $120
Oil Cap (New Style) - $105
Fuel Filler Cover (Old Style) - $80
Fuel Filler Cover (New Style) - $90
Radiator Cap - $60
ACCESSORIES:
Support Towel (107x19cm) - $35
Muffler Towel (102x20cm) - $35
Bath Towel (120x60cm) - $60
Sport Towel (110x40cm) - $45
Hand Towel (34x34cm) - $30
Hip Bag (30x20x10cm) - $105
Knapsack (34x46x4cm) - $45
Camera Case (13x18x4cm) - $60
Key Ring Type E - $60
Key Ring Type P - $30
Key Ring Type J - $35
Key Ring Type G/A - $50
Key Ring S-Tune II - $35
Mug - $40
Team Colour Strap - $35
Neck Strap - $45
https://www.sau.com.au/forums/topic/44341-nismo-grp-buy-more-accessories/
  • Replies 337
My my you have been busy! I like the web page! :rofl:
I'll take a "Key Ring Type G/A"
Thought I should put pics as I had so many pms last time with people not knowing what was what....! No probs with key ring, will note u down.
am in for a group buy. how soon until everything is bought n can b delivered
Last 2 buys it took about 2 weeks to get enough interest so should be the same this time. Basically when we get enough orders it will be placed right away.... should mean everyone will have parts in about 4 weeks from now.
Dave.
Okay, I'll get in on this one.
I'll take:
1x Oil Cap (Old Style) - $120
1x Low Temperature Thermostat - $110
1x GT Titanium Gearknob - $210
PM me your bank account details :rofl:
Where's the R32 exterior stuff? Not feeling the love Dave...
I was thinking the same thing, but Nismo doesn't produce a lot of exterior stuff for the R32 -- it was released a little early for the whole... *ahem* "ricer" scene :)
So many trinkets, so little cash.
I remember someone in a previous Nismo GB thread saying that one type of fuel filler was just a stick on cover and one wasnt: anyone know which is which?
Cheers,
Lucien.
Hi Dave.
I've already placed an order and paid the money......you provide a great service.
Can you get the NISMO engine and transmission mount kit?
Can you get the NISMO oil pan Baffle upgrade kit?
Thanks Phillip
[email protected]
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
