Trevor Dawson-Grove is his dad, thats how I tracked him down. Using that automotive-industry.com.au URL I found his dads number. From that I called the number and it just so happened that dAVE was there with him in QLD.
  • Replies 337
Yeah, I guessed as much. We should both be promoted to detective :D
Ok, well hopefully David will do the right thing and return my money to me. Out of interest has he given you any reason for the delays and lack of contact?
Cheers mate,
Richard
You deposited money into his bank account right? So you would still have his bank account details?
Then you can make a complaint to his bank and get all his accounts frozen with that bank for fraudalent activities. You can also make a police report if there are alot of people still waiting for their parts / money back to go along with this which will help getting his assets frozen.
That might make dave actually reply to you guys.
Nice, I'll call the bank today and get his accounts and assets frozen. I'll speak to the police also and check what our rights are. Still.......all this could be stopped if he'd just post! dAVE I'll wait till 3pm today before I call, personally I'd just post if I were you!
get the names and details of all the people he owns money to and take it to the police and file a report.
Get the federal police involved as they can freeze assets very easily, credit cards, loans etc.
Call and leave a message if he doesn't answer and/or sms and let him know he has till 3pm today to make contact with you before you take this to his bank and the police...
If you want i'll call/sms him and leave the message?
Yeah why was this thread locked ? the group buy hasn't finished, please don't lock it again until it has :)
I tried calling, no answer.. has anyone received any money back yet?
no money recieved, no parts received, i got to the stage where i was forgetting about it coz its been so freakin long, and it didnt look promising, locking the thread gave me no idea what was goin on so that didnt help either, hoping for a post from dave, but surprise surprise there was nothin....
ben...
hey, i have been following the group-buy for sometime now was wondering if anyones got there money or stuff yet? also shouldnt the mods step in and remove Dave from the mod list on the FOR SALE section???
I know the mods really cant do anything but for him to still be a mod after all this is alittle be **** me things
It still amazes me how Dave was the person who started the Known Bad Traders (http://www.skylinesaustralia.com/forums/sh...ead.php?t=33686) thread! Shouldn't one of the mods add Dave to that thread... :uzi:
The WHOLE for sale section was locked coz of the new area but it was un locked, wasn't just this thread. Yeah as I said I spoke to dAVE about a week ago and he said he was waiting for pay so he could get money orders to send back to us.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
