  • Replies 337
The WHOLE for sale section was locked coz of the new area but it was un locked, wasn't just this thread. Yeah as I said I spoke to dAVE about a week ago and he said he was waiting for pay so he could get money orders to send back to us.
Did he offer any explanation as to what happend to our money/parts in the first place? If he's waiting to get paid to pay us back he has obviously spent our money on something.
That's all I want. 1. money 2. explanation. I'm not fussed with the whole retribution or banning him or beating him up. Money and explanation will be enough for me. but if those two things aren't forthcoming then I may have to consider those other options...
Richard
That's all I want. 1. money 2. explanation. I'm not fussed with the whole retribution thing or banning him or beating him up. Money and explanation will be enough for me. but if those two things aren't forthcoming then I may have to consider those other options...
Richard
I hope no one has lost more than a few hundred, I can see this getting messy real quick if thats the case
Hope everything gets cleared up
Chris
He did say somethign but I don't really take what he says with all that much merit. I mean how long have we been waiting!
Said something about the supplier didn't deliver and ripped him off or something along those lines. He was waiting for his pay so he could draw the money orders.
EVERY time I speak to him I say go an post and let ppl know. I've said it at least 5 times now. I told him most ppl would understand if he got on here but yeah....
Yep was all my stuff. Got the Nismo catalouge, Keyring and a Postal cheque for $40 for the lighter he couldn't get! Hopefully this means all your parts are near too! Looks like all the hard work was worth it in the end, just a shame it took so long!
bit suss that you're the only one who got thier stuff/refund and you're the only one who has been in contact with him... (ie he figures he'll only refund whoever hassles him)
Did you give him our details of what he owes us?
Well yeah, if you remember I sent that e-mail with everyones stuff in it. I don't know if he has all your mailing address's or not. If not then you'll have to try and contact him via phone. It can be done as I found out I just had to try ALL the time.
Guest
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
