Hi Guys,
I just wondering if there any clearer picture of their Double din setup that has the 2 din, A/C controller, and stock boost gauge. I seen that it cuts out the bottom bit and install the A/C controller on the cup holder or blank section. I just need a clearer picture if possible.
Cheers
https://www.sau.com.au/forums/topic/443415-c34-double-din/
Take out the DIN rack and see for yourself. The drink holders can be removed, but its not a standard DIN slot, so you will have to do some custom brackets if the rack for the drink holder doesn't match. I thought about doing it years ago, but it wasn't worth the hassle.
https://www.sau.com.au/forums/topic/443415-c34-double-din/#findComment-7289721
On second observation, the 2nd picture in the middle showing what looks like the dash hasn't been cut off? Hmmm so confusing lol. Maybe really have to open up and see how can custom fit it nicely, without being looks like "R2D2" into dash.
https://www.sau.com.au/forums/topic/443415-c34-double-din/#findComment-7292403
By the looks of it the middle photo, shows that you're able to fit it without cutting the din's surrounding and it'll still fit.
You can see how there's a much greater gap between the little storage beneath it and the A/c control. Whether as the other two, they cut the din's surrounding making it a complete 4 din slot.
Am I making sense?
Pretty much, you can cut the din's surrounding/facia or leave it.
https://www.sau.com.au/forums/topic/443415-c34-double-din/#findComment-7292407
I've been thinking about doing this for a while now too.. really like rhe gauges where they are (dont like sticking them all over the column and wherever else) but want a double din stereo.. following thread with much interest
https://www.sau.com.au/forums/topic/443415-c34-double-din/#findComment-7292805
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
