Hey guys since I got my car iv done a few mods already iv put in r34 seats replaced most of my old crappy dash with newer parts, atm iv bought a gtr front bar and will be having it painted this weekend along side my rear bar the needs new paint, I will be buying a gtr style side skirts sometime soon and will be painting my rims r32 gtr stock rim grey
I will be tinting the windows and also be buying a gtr boot wing. If anyone has some ideas please let me know
I have also painted all the chrome bits + windscreen wipers post-134686-14006312094441_thumb.jpgpost-134686-14006312326914_thumb.jpgpost-134686-14006313026146_thumb.jpgpost-134686-14006313197077_thumb.jpgpost-134686-14006313332224_thumb.jpgpost-134686-14006313518858_thumb.jpgpost-134686-14006313661493_thumb.jpgpost-134686-140063137649_thumb.jpgpost-134686-14006313920228_thumb.jpgpost-134686-1400631440288_thumb.jpgpost-134686-14006314530076_thumb.jpg
https://www.sau.com.au/forums/topic/443424-r32-build/
  • 3 weeks later...
looks nice, haha u got it resprayed and they put the GT badges on the wrong spot, just like mine. They sit a bit lower. Anyway, i would put type M sideskirts on it with rear pods, and make sure u get a front lip and vents for the front bar. Also put a gtr spoiler and n1 lip. Just my opinion.
Also, how do u take the roof lining off? i need to paint mine too. Your's looks nice now, how many coats did you do?
Edited by IM-32-FK
https://www.sau.com.au/forums/topic/443424-r32-build/#findComment-7305987
Well this is the one I brought is that what your talking about post-134686-140218763986_thumb.jpg
And these are the skirts + pods I'm buying post-134686-14021876771094_thumb.jpg
Okay now to take the roof lining off, you need to remove the sun visors the clips pop of on the and then you remove them with a Phillips head
Then take out all of the roof lights by just pulling them out and unplugging them,
After that the seat belt have to come off so you can take the trims around the car of. The roof lining should pull out but be carful not to bend it
I put about 6, giving we used 2 cans spraying all the lights + visors
All up cost me $64
https://www.sau.com.au/forums/topic/443424-r32-build/#findComment-7306022
I got if from a guy in Penrith, sold it for $140 with a crack in it getting repaired + paint on Tuesday for $250
An if I take my re bar off he will fix up the different colours the guy I brought the car of used a spray can on it
If you want one I know where to get a brand new fiberglass one for $350+
https://www.sau.com.au/forums/topic/443424-r32-build/#findComment-7306170
  • 1 month later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
