Thinking about buying a Wrecker RB30, one wrecker I found said they have a long block which has been sitting on the shelf for years and they could do me that for $350, says it will
turn by hand but they cant do a comp test on it for me.
How long can an engine sit on a shelf for without getting rust in the bores? is it a bad idea to even buy off the shelf engine if you cant do a comp test?
https://www.sau.com.au/forums/topic/443427-wrecker-engines/
Too much.
I bought one complete with cut loom trans head manifolds starter etc, for 250 or 300 (can't remember) and he delivered it! Was comp tested and from a relatively low k car.
Sold head for 50 then binned the rest.
https://www.sau.com.au/forums/topic/443427-wrecker-engines/#findComment-7289308
found another that's a 1 owner 120k old apparently and was running when pulled out,
would a comp test be reliable if the motor is cold and not started for a few months, could I even do damage to the motor if its a bit dry and dirty from sitting?
https://www.sau.com.au/forums/topic/443427-wrecker-engines/#findComment-7289607
